Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 08-18-2013, 08:46 AM
JWM59's Avatar
JWM59 JWM59 is offline
Vehicle: 2013 Dodg Ram
Rep:148
JWM59 will become famous soon enoughJWM59 will become famous soon enough
I have never once in all the vehicles I have owned had shifter linkage go bad. I have had other things go bad for myself or others which required SHIFTING the car into neutral and pushing onto the side of the road or having it pulled by a tow truck. Very easy process. Seems to me the process got a little more difficult. I work on cars and monkey rigging a temporary fix on some linkage so you can get home is a lot easier than fixing and electrical problem of any sort. More reliable, yeah right!
Old 08-23-2013, 09:16 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
Sounds like, bottom line, floor-mounted shift lever versus column shift lever versus rotary shift knob is a matter of personal preference.
The 6-speed trans is standard on the ST models only for 2014 (not available on other models), and the floor shifter is packaged with bucket seats, only with the 6-speed trans.
The 8-speed does not use the existing column- or floor-mounted shift levers, because (as noted) it is fully electronic - there is NO mechanical shifter cable connected to it (the existing shift levers are for a mechanical cable). So any kind of switch (rotary knob, pushbuttons, touch screen, or shift lever that was merely electronic) can work with the 8-speed. But before you start wishing for a console-mounted shift lever for your 8-speed truck, take a test drive in a 2014 Jeep Grand Cherokee, or a 2012-2014 Dodge Charger or Chrysler 300, with the 8-speed trans. They all have a console-mounted shift lever that is, well, less than optimal (to put it mildly, in my personal opinion).
Old 08-23-2013, 09:27 AM
Yankee Yankee is offline
Vehicle: 2014 ram 1500 quad slt 4x2 b/h
Trim Level: SLT Big Horn
Rep:40
Yankee is on a distinguished road
So far, ive driven one 1500 on a 1/2 hour test drive, and mine for another about as long on Wed...I pick it up and bring it home tomorrow. I "got used to" the so-called "shifter" location immediately...except for a couple times i found myself reaching for something that wasnt there...the console on the other hand, is HUGE with buckets...im sure i can find SOMETHING to do with my right hand besides rest it on a stalk........as i previously opined, most of the time folks with automatic anythings arent "shifting" at all...its just an affectation..and the truck does have the capability of being taken thru the shift points manually. Having said that, getting used to the smoothness of the shifting was somewhat disconcerting...for all practical purposes, i felt nothing...I I belong to the generation that was taught that a bang or lurch into gear was actually BETTER than a smooth shift...never could understand that, but it doesnt matter....I think ill love the thang....hell, I better.....
Old 08-23-2013, 02:33 PM
toober's Avatar
toober toober is offline
Trim Level: Tradesman
Rep:26
toober is on a distinguished road
As long as they still require you to stick the key in the console, the rotary knob might as well be right next to it, your hand is already there.
Old 08-23-2013, 02:37 PM
Rep:40
Hmmmm...mebbe maw nature shouldve rigged guys to p*ss thru their kneecaps...would solve a multitude of problems with latrines and toilet seats....hehehehe....and, I see some cars dont require keys....interesting tho...back in the day, my right hand WAS more interested in kneecaps come to think of it....
Old 08-23-2013, 05:03 PM
gwilburn's Avatar
gwilburn gwilburn is offline
Vehicle: 2014 Ram 1500 Crew 4x4
Color: Maximum Steel Metallic
Rep:108
gwilburn will become famous soon enoughgwilburn will become famous soon enough
Mine won't require me to stick the key in the console... I won't even remove it from my pocket.
Old 08-23-2013, 06:06 PM
toober's Avatar
Rep:26
This should have become standard technology over a decade ago.
