Old 07-31-2013, 01:31 AM
rockyram21 rockyram21 is offline
Vehicle: 2009 Dodge Ram Hemi
Rep:26
rockyram21 is on a distinguished road
Default replacing 2 ohm with 4 ohm
Have the Alpine upgraded system in a 09.If i replace speakers that are 4 ohm instead of 2 ohm will I really lose much volume?I have done some googling but once again come away with 50/50 answers.it just seems that at least locally 4 ohm speakers are easier to come by.Cheers.
Old 07-31-2013, 10:33 AM
Graygoose's Avatar
Graygoose Graygoose is offline
Vehicle: 2011 Ram Express
Rep:92
Graygoose will become famous soon enough
You'd lose about half the power. Impedance on the amp would drop 50%.
2011 White Ram Express, Custom American Racing 2-piece forged, Nitto 420s 22's,Extang Trifecta, Belltech 2/4 drop, Magnaflow catback,KICKER sound system,CodeAlarm remote start, '13 Retroshop Headlights and Tail lights, Bedrug, Custom MGP Caliper covers, LED reverse lights, AAC interior LED and licence plate LEDs, BT Catch Can,Weathertech mats
Old 07-31-2013, 10:42 AM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
Don't worry about it. Have you measured your OE speakers? Not all are 2 ohm (at least in mine). You have way more issues to worry about when replacing the OE alpine speakers. There is not a full-range signal, so the only easy-swap are the dash speakers.
Old 07-31-2013, 11:27 AM
Graygoose's Avatar
Rep:92
But if they are indeed 2 ohm (stamped on back) and replaces with 4 ohm, he will lose power. While possibly nil, still will reduce output.
Old 07-31-2013, 11:32 AM
Grubrunner's Avatar
Rep:3883
I'm not sure if the front drivers use an active or passive crossover but either way, messing with the OEM impedance will harm compatibility and/or syncing of all components in the chain to work optimally.
I would stick to the same impedance as what you're replacing if in fact they are 2 Ohm.
Two ohm speakers are all over the net' if local searches yield no results.
Grub out!
Old 07-31-2013, 11:49 AM
Rep:26
Thanks for the replies.I,ll search for 2 ohm dash speakers and leave the doors for now.Disconnected the center channel and it already sounds better.
Old 07-31-2013, 12:54 PM
Grubrunner's Avatar
Rep:3883
Just make certain they are in fact 2 ohm prior to purchasing.
Good luck and keep the board updated.
Grub out!
Old 08-04-2013, 11:52 PM
burtonxrider21's Avatar
burtonxrider21 burtonxrider21 is offline
Vehicle: 2012 dodge ram 1500 sport
Rep:92
burtonxrider21 will become famous soon enough
I have been having a hard time finding any 2 ohm speakers as well... I am really starting to hate this so called "premium" sound system!
Old 08-05-2013, 10:15 AM
Graygoose's Avatar
Rep:92
Thats kinda the problem with OEM, most sue 2 ohm door, and or 1 ohm subs.
Old 08-05-2013, 02:56 PM
Rep:92
Would installing the Kicker 77KICK45 amp allow you to use 4 ohm dash and all four door speakers? I really don't want to bother upgrading everything if its not going to make much of a difference!
