Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
ZDOG
Old 07-31-2013, 04:35 AM
Scratcher09 Scratcher09 is offline
Vehicle: 2001 ram 1500 5.2
Scratcher09 is on a distinguished road
Default Help with chirp from behind gauges
My '96 1500 occasionally makes a muffled high pitch chirp from what seems to be behind the gauges under the dash. It is random and only happens once in a while. Any ideas?
Old 07-31-2013, 07:40 AM
Mate2011RT's Avatar
Mate2011RT Mate2011RT is offline
Vehicle: 2011 Ram R/T
Rep:59
Mate2011RT will become famous soon enough
loose dash clip?
Old 07-31-2013, 10:31 AM
Graygoose's Avatar
Graygoose Graygoose is offline
Vehicle: 2015 Ram Bighorn
Trim Level: Bighorn
Rep:108
Graygoose will become famous soon enoughGraygoose will become famous soon enough
Speedometer cable.
2015 Crew Cab Bighorn
Old 07-31-2013, 11:39 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Is it rhythmic (when it's happening), or just an occasional chirp without any pattern?
Old 08-01-2013, 02:53 PM
It is just a single chirp--always the same. Does not sound mechanical. Sounds electrical--if that makes sense.
Old 08-01-2013, 04:58 PM
Vehicle: 95
Rep:1776
Try putting your head under the dash and take it for a ride down the street...
Just kidding. The reason I was asking if it was rhythmic is because that usually accompanies the speedometer.
Old 08-03-2013, 01:44 AM
How can I check to see if it is indeed the speedometer and is there any way to fix it?
Old 08-03-2013, 09:36 PM
TEDD's Avatar
TEDD TEDD is offline
Vehicle: 1998 dodge ram
Trim Level: gone
Color: Green
Rep:49
TEDD is on a distinguished road
Hahahahahahaha!
Old 08-04-2013, 07:14 PM
Vehicle: 95
Rep:1776
watch the needle and listen there'll be a slight fluctuation in the needle.
Maybe you could hire a chirp expert to double as a GPS?
Old 08-05-2013, 10:22 AM
Graygoose's Avatar
Trim Level: Bighorn
Rep:108
disconnect it from the cluster, if it quits you will know its the speedometer cable.
