Old 07-31-2013, 09:45 AM
Korn3199 Korn3199 is offline
Rep:54
Korn3199 will become famous soon enough
Default pulls to the left...
truck's been pulling to the left, pretty badly, since the day i got it. only at high speeds. anybody else have the issue? i would say it's obviously just a wheel alignment fix, but i've heard of air suspension being the culprit as well.
anybody go for a wheel alignment only to have to go back to adjust the suspension (re-calibrate)?
Old 07-31-2013, 10:33 AM
Grubrunner's Avatar
Rep:3883
Is this happening under braking or just driving or both?
Grub out!
Old 07-31-2013, 11:05 AM
TinMan68 TinMan68 is offline
Vehicle: 2013 Dodge Ram 1500 Express
Trim Level: Express Quad Cab
Rep:45
TinMan68 is on a distinguished road
I had this happen after a tire rotation. When I had to brake hard it pulled to the left and then came right back to straight. It lasted only a few days and its been fine since. That's been almost a thousand miles ago. I have no idea what it was. And the guy that does my work is as picky as I am. That's why I always go to him. He's independent and works by himself. I've known him for 25 years at least!
2013 Dodge Ram 1500 Express Quad Cab 5.7L Hemi With 6 Speed Automatic And 3:55 LSD Gears and 20 Inch Rubber
2002 A6 3.0L 30V Quattro Avant Auto
2003 Nissan 350Z Enthusiast Model 6 Speed Manual
Old 07-31-2013, 01:07 PM
keeptrucking keeptrucking is offline
Vehicle: 2003 Dodge Ram
Trim Level: silver
keeptrucking is on a distinguished road
Default no alignment, may need new tire
Before to do any wheel alignment, reverse the front tires
Put the right tire in the left side and the left tire on the right side
If after doing this, the truck start pulling to the right, you have a bad tire
and you will have to buy a new one
Old 07-31-2013, 08:24 PM
Rep:54
it happens when i brake as well, like if i'm slowing down for a toll booth, i can feel it pull until i reach about 30 mph.
weird thing is, sometimes it rides just fine. i'd say about 80% of the time, it's pulling at highway speeds.
i'll give it a shot, thanks
Old 07-31-2013, 11:08 PM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
I would try this 1st. My truck has a slight pull. I have to have it aligned ever 3 months. After some off roading I keep knocking the alignment out and some bad potholes here.
Old 07-31-2013, 11:28 PM
browndawg's Avatar
browndawg browndawg is offline
Vehicle: 2012 ram 1500 4x4 express rcsb
Color: true blue pearl
Rep:101
browndawg will become famous soon enoughbrowndawg will become famous soon enough
take it to the dealer, they will tell u this is normal and send u on ur merry way. booom problem solved lol.
Old 08-01-2013, 09:23 AM
mechtech mechtech is offline
Vehicle: 2014 Dodge Ram
Trim Level: Sport Quad
Color: silver
mechtech is on a distinguished road
I had this problem with my truck since new.Took it back to the dealer and they re-calibrated the air suspension.No more pulling and my steering wheel is centered now.
Old 08-26-2013, 09:47 AM
White392's Avatar
White392 White392 is offline
Trim Level: Longhorn Laramie
White392 is on a distinguished road
I had the same problem and the dealer told me tat it was my BF Goodrich tires. They reversed the front tires and said that it was pulling to the right but the alignment was dead on. I left and it was still pulling to the left.
Old 08-26-2013, 10:40 AM
bowieknife's Avatar
bowieknife bowieknife is offline
Vehicle: 2013 Sport CC, 5.7L, 8spd
Trim Level: Sport Crew Cab
Rep:71
bowieknife will become famous soon enough
Send a message via Yahoo to bowieknife
Mine pulls slightly to the left at highway speeds as well. I don't have air suspension so I'm guessing tires. I'm going to give it another 500 miles and have the front tires swapped (left to right). It's not a major pull left, but noticeable. For local driving, tracks straight as an arrow if accelerating or braking.
