Old 07-31-2013, 11:52 AM
Tacsavage Tacsavage is offline
Vehicle: 2005 Dodge Ram 2500
Trim Level: SLT Sport
Tacsavage is on a distinguished road
Default 4" Superlift questions
Picked up a 2013 crew cab 1500 sport last week. Coming out of a 2005 2500 that is lifted on 35 toyos. Really leaning toward a 4" superlift with Bilsteins. How does this lift ride compared to stock? I need a little more civil of a truck as a daily driver so I was planning on the new toyo at2 in 305/50r20 on 20x9 -12 offset or 20x10 -24 offset. Once I pick up another commuter vehicle in a few years go back to 35s. I also would like to keep at least a 1.5 in of rake so it doesn't squat too low with my boat on it. Do I need to add a spacer to the rear in addition to the superlift springs? Will lift kit shocks still work with additional spacer? Thanks for he input.
Old 07-31-2013, 04:16 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Well with this kit if you want 1.5" rake you will have to leave the Bilsteins at the 0 setting
How it will ride?
It should ride fairly close to stock.
If you require this kit, it is something we provide....mind you we can provide you a 4" BDS kit which will work out to be less and its of similar to greater quality
Let me know
sales@revelperformance.com
Old 07-31-2013, 06:48 PM
Chickenhole's Avatar
Chickenhole Chickenhole is offline
Vehicle: 2011 ram sport
Rep:21
Chickenhole is on a distinguished road
I think it's overpriced, as fastnugly said bds is better quality. The 4" has good ride quality, but as soon as you add height with the bils, I found atleast with mine there was wobble in 4x4 high. @1.4, I had 1" rake
4" MOPAR LIFT, BILSTEINS@2.1, 12" REAR BILSTEINS, 1.5 TGC COIL SPACER, 325/60/20 NITTO TERRA GRAPPLERS, AFE STAGE 2, XD ROCKSTARS
Old 08-21-2013, 08:03 PM
rangerjoe1 rangerjoe1 is offline
Vehicle: 2013 1500 Laramie
Color: Blue Pearl
rangerjoe1 is on a distinguished road
Not impressed with the BDS at all. Traded in a Tundra Maxx with a 7" BDs and 37" trails. A lot of rubbing issues. As well had a history id parts prematurely wearing out. BDS was reluctant to stand behind them but did once. They suddenly changed their design slightly. So support isn't one of their stronger suits
Old 08-21-2013, 10:37 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
heard this about bds before... not every kit is going to work out for everyone. i would still go with a bds or a zone for a 4'' lift... i know with around 10'' of lift i ride just about on stock
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 08-24-2013, 12:57 AM
Revel Performance
Rep:1804
It's sad BDS did not work out for you.
But it's truly the odd situation and I'm not saying I don't believe you must have gotten a few wrong people.
None the less, there is much more positive than negative
It also sounds like someone may have sold you the wrong setup.
Offset of rims is crucial. As are tire width vs lift height.
We go through with customers what they want to achieve look wise and functionality and we advise them if there will be rubbing and where to correct it.
But that's what is sounds like to me
Then to top it off with bad service would piss me off too
