Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 08-03-2013, 06:04 PM
GuyGene's Avatar
GuyGene GuyGene is offline
Vehicle: 1993 Dakota
Engine: 1992-1991 239ci (3.9L) Magnum V6 180hp
GuyGene is on a distinguished road
Here's the way I do it:
Air filter dirty, change.
Hot, use air.
Go from A to B in a safe manner.
Done.
That old man, he don't think like no old man. "He's pinned under an outcropping of rock. Lucky for him, the rock kept the dirt from burying him alive". Dirt, it's nothing but dirt, I tell ye...
"I thought I was wrong one time, but I was mistaken." Command Sergeant Major Jim
Old 08-04-2013, 06:32 PM
PatrickJ PatrickJ is offline
Vehicle: 2005 Ram SLT
Rep:19
PatrickJ is on a distinguished road
I put my Ram into neutral when I'm at a red light or a slow drive-thru restaurant - good idea?
Old 08-05-2013, 03:13 AM
urdone21 urdone21 is offline
Vehicle: 2013 Ram 1500 Express
Color: Mineral Gray
Rep:23
urdone21 is on a distinguished road
I'm considering a tuner for better MPG. Anyone get better MPG from a tuner?
Old 08-05-2013, 08:27 AM
Grubrunner's Avatar
Rep:3883
Possibly.
But, by their very nature, I doubt if anyone's had the opportunity to accurately test any tuners out purely for MOG gains, while not taking into the equation and overlooking the HP & TQ benefits.
Grub out!
Old 08-05-2013, 09:45 AM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
It would be less load on the engine, but more load on the transmission when you put it in gear. I also believe the throttle doesn't move, so the fuel metering won't change, especially on a newer engine/transmission.
I have recommended to people to NOT do that on the basis of safety (on the streets)...
Old 08-05-2013, 10:28 AM
Warthog Fixer's Avatar
Warthog Fixer Warthog Fixer is offline
Vehicle: 2011 Dodge Ram 1500
Rep:20
Warthog Fixer is on a distinguished road
Lightbulb old skool stop-start tech
If I know i'm going to be stopped for a while or so; I put the transmission in neutral or park, then reach down on the dash just to the right of the steering column and turn the key one click to the left. BOOM awesome fuel efficency!
For my brothers in the '13 models and up it's even easier, you guys have PHD tech!!
Old 08-06-2013, 11:43 AM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
Originally Posted by TRCM View Post
Above 40 mph, it's better to have the ac on, below that, windows down
And the idling thing was true with carbs, but not with FI.
This statement can only be half true. A single start up uses a definitive amount of fuel. If an engine is at idle for a given amount of time that uses less than a start up then yes start up is less fuel efficient than idle. So when the "idle time/fuel consumption" exceeds a "start up consumption" idle becomes less fuel efficient.
Old 08-06-2013, 03:22 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Originally Posted by DRX350 View Post
I agree with all those EXCEPT the air filter one.
I don't care what you say, a clean air filter will get better mileage. True, the ECM will adjust for the available air, but you'll lose power in the process, thus requiring more throttle and using more gas.
My wife's 2007 Kia got 37mpg with a stock air filter, and 42mpg with a K&N drop in replacement on the same exact trip. Shoot, even my old '96 Dodge went from 13mpg to 15mpg with the addition of a CAI...
I disagree. My 01 had a K&N drop in and I actually lost some mpg. My old 02 GMC Sierra saw no difference with a K&N drop in filter and then later with a cut open airbox.
These new vehicles usually have good airboxes. Not restrictive ones like in the past.
Old 08-07-2013, 08:37 AM
spp spp is offline
Vehicle: 2008 Jeep Wrangler
Trim Level: Sahara
Color: Steel Blue
Rep:106
spp will become famous soon enoughspp will become famous soon enough
I believe that time is between 3-5 minutes depending on engine. Don't take that as gospel though but I thought I saw the 5 minute thing in the owners manual.
Old 08-27-2013, 10:59 PM
Jason Rosenzweig Jason Rosenzweig is offline
Vehicle: 2009 Dodge Ram 3500
Jason Rosenzweig is on a distinguished road
Reason a/c is better than open windows is because of aerodynamics, the air coming in the cab causes drag. I'm not sure if you have a sliding rear window if that will actually help reduce drag or not tho.
