tonneaucovered.com
Old 07-31-2013, 11:32 AM
Parkersdad Parkersdad is offline
Vehicle: 2013 Dodge Ram 2500
Color: Mineral
Rep:21
Parkersdad is on a distinguished road
Default Help Me Understand Transmissions
I have a 2011 Hemi with the 5 speed transmission. I keep wanting to trade simply because of the 8 speed transmission. I pull a 5500 to 6000 pound trailer 10 to 12 times per year and half of that in the mountains. My truck does well but will the new 8 speed help me? Sometimes even empty if at the wrong rpm's my truck will not gear down and haul ass. Can someone please clear this up for me?
Old 07-31-2013, 11:57 AM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:649
Thunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to all
The 8 speed's ratios are spaced better than those of the 5 speed so you will have more available power while you are towing. It is also a tougher transmission with a higher torque rating than the 5 speed, and will get you better mileage.
Go test drive an 8 speed and you will see what I mean. Granted you won't be towing but you will still get a feeling for the better power availability with the 8 speed. My dad has the 5 speed in his '09 and the difference is night and day. The 8 does a much better job of keeping the engine in its power band, and the lower 1st gear makes starting with a load easier.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back (video) Tuftruck 1223V progressive rear coils.
Old 07-31-2013, 12:03 PM
Graygoose's Avatar
Graygoose Graygoose is offline
Vehicle: 2015 Ram Bighorn
Trim Level: Bighorn
Rep:108
Graygoose will become famous soon enoughGraygoose will become famous soon enough
8 speed keeps the truck in the optimal gas mileage rangs, while lower ratio will help on gas mileage, dont know if it can justify trading in and possibly spending alot more cash.
What gear ratio does your '11 have?
2015 Crew Cab Bighorn
Old 07-31-2013, 12:16 PM
Color: Mineral
Rep:21
Mine has the 3.92 gears
Old 07-31-2013, 12:20 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
8 speed will be better, but not worth trading IMO. The biggest difference would be starting out power. The 8 speed is geared lower so will pull from a stand still better. The spread of ratios is also better but I don't think that'd be as noticeable. The final ratios are the same, so no difference cruising(other than a little difference in parasitic loss as I'm sure the 8 speed is more efficient).
Sean
Old 07-31-2013, 12:59 PM
Graygoose's Avatar
Trim Level: Bighorn
Rep:108
Lucky, I'd keep what you have honestly.. But thats just me
Old 07-31-2013, 08:29 PM
Trim Level: sport
Color: green
Rep:682
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i would like to see how the 8 speed holds up for a few years before i get one. sit tight for a bit op.
Old 07-31-2013, 08:51 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
I just wanted to say, that 1st gear of a 4.71 gear ratio mated to a 3.92 rear gear sounds like a kick ass combo for your use.
Old 08-03-2013, 07:02 PM
wolfman01 wolfman01 is offline
Vehicle: 2013 Ram 1500 QC 4x4
Trim Level: Bighorn Edition
Rep:126
wolfman01 will become famous soon enoughwolfman01 will become famous soon enough
I have to say sort of. I've driven an 8 speed auto and can attest that the 8 speed is much more willing to let you have that top ratio at moderate speeds. My "6" speed will not readily let me have "6th" gear until 62 - 63 mph in many cases. I've often had to accelerate up to that speed to get my truck into the top gear before letting it cost back down to the 60 mph that I try to keep to in my truck to maximize fuel economy. Once there, it'll hold until 57 mph before a forced downshift will occur.
The 8 speed will happily give you 8th gear @ 55 mph, letting you waft along in MDS mode at 1100 RPM. IIRC, 60 mph was also about 150 RPM lower, so there had to be something different between the two to allow for the slight drop in RPM over my truck.
Yeah, I know I'm a geek for trying to hypermile a truck, but what can I say. I have been able to squeeze as much as 24.7 mpg out of mine, and I think I still have enough room to push it to the 25 mpg mark, as that figure came in despite having to engage in a high speed flat out run to get around a huge piece of oilfield equipment, the pilot vehicles, and a short train of people not wanting to pass, and fighting with the construction zone in Cheyenne WY at the Flying J.
2014 Chevy Spark (3k)
2013 Ram 1500 Quad Cab 4x4 Hemi 8 speed (7k)
2004 Saturn ION Redline (9k)
1995 Tiffin Allegro Bay (46k)
1989 Oldsmobile Cutlass Cierra (97k)
