United Radio
Old 08-01-2013, 11:46 PM
Yotaconvert Yotaconvert is offline
Vehicle: 2013 Ram
Color: Black Baby
Rep:172
Yotaconvert has a spectacular aura aboutYotaconvert has a spectacular aura about
Default Searched and lost more hair..leveling question...
Looking to level out me 2013 2wd crew.
I would like to get it to a somewhat close stance to the first one posted here.
http://www.ramforumz.com/showthread.php?t=139401
I cannot find for the life of me part numbers to run for the 2013 2wd ram to figure out what it is I need.
I want to do it right and not go uber cheap. Suggestions are greatly appreciated.
Bear with me im a newb when it comes to this stuff.
2013 Black Beauty
-Spyder Halo/Projecter/LEDs
-SB CAI
-Flowmaster 40
-Bullydog Hemi GT
-MB Rims (cuz im cheap lol)
Old 08-02-2013, 12:03 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Well you are 2wd so you can't run the same kit as a guy with 4x4.
Daystar and Fat Bob's Garage are the only sources of coil spacers to level the 2wds that I know of. (Taken from another guy on another forum)
I don't think anyone makes steel spacers for 2wd yet. Only the polyurethane ones. Which I'm personally not a fan of but it's really your only choice unless you go with a CST 4" or 7" lift
Old 08-02-2013, 02:51 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Readylift also makes this kit for a 2wd. 2.5" front and 1.5" rear. Check out the first truck in this thread... http://ramforumz.com/showthread.php?t=144261.
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched -CST/Pro Comp 6" Lift - 35x12.50 ATZ P3 and 20x9 +1mm Fuel Mavericks -AMP Power Steps -8k HID -HEMIFEVER Tune
Old 08-02-2013, 04:13 AM
Vehicle: 2013 Ram
Color: Black Baby
Rep:172
Thanks so much guys I really appreciate it!
2013 Black Beauty
-SB CAI
-Flowmaster 40
-Bullydog Hemi GT
Old 08-02-2013, 06:31 AM
012RAMbo's Avatar
Rep:264
No problem man! There are a bunch great members on here that are very knowledgeable and helpful. Good luck modding, its addictive!
Old 08-02-2013, 12:21 PM
MangoTangoMofo's Avatar
MangoTangoMofo MangoTangoMofo is offline
Vehicle: 2010 1500 Sport 5.7L Hemi
Trim Level: Sport Quad Cab
Color: Mango Tango
Rep:98
MangoTangoMofo will become famous soon enough
It always makes you feel good when someone else posts a pic of your truck, so thank you!
With that being said the ready lift that 012RAMbo recommended will give you a VERY similar stance to my truck. Check out the 5th post by 1LOWBLKRAM on the link he sent you.
One big think to keep in mind when levelling your rig is that the biggest impact comes from the wheel and tire combo you decided to run. If you want to stuff 35” tires under there (like I and so many others have) you will need to run a wheel with a different offset then stock (somewhere between 0 and -12) in order to clear everything which pushes your tires out of the wheel well giving you the aggressive stance you're looking for. You also gain 1 inch of lift simply by going from the stock 33” tire to a 35” tire.
The reason I bring up the wheel/tire combo is this, if you run your stockers you won’t get the same look or stance by simply running a levelling kit. Your truck will look lifted and definitely sit higher then stock but it’s the whole package lift, wheels and tires that tie everything together.
Hope this helps.
5x11x22 Magnaflow with a resonator delete // Rough Country 2.5F&1.75R level kit // 17 XD Cranks // 35x12.5x17 Toyo MT's // Air Lift 1000 // Armor Thane bed liner // Century Ultra Sport Canopy // Yakima Roof Rack // Mopar side steps // Custom Browning Mudflaps
