Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Place your Ad Here!
Old 08-01-2013, 10:55 PM
Dodge2500v10 Dodge2500v10 is offline
Vehicle: 1999 dodge ram2500
Trim Level: Extended cab
Dodge2500v10 is on a distinguished road
Default Help
I have a 1999 dodge 2500 4x4 lifted and when I stop it pulls to the right
Need help does anyone know what it could be?
Old 08-01-2013, 11:41 PM
tazman43 tazman43 is offline
Vehicle: 2001 dodge 2500 4x4
Trim Level: power wagon
Color: white/gun met gray
tazman43 is on a distinguished road
caliper or common to have a rubber hose inner liner to calapes.jack up frone end hit brakes let up try to turn tires.one will turn hard. crack bleeder loose if pressure releases and tire rolls.rubber line is shot.
Old 08-02-2013, 02:04 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I second the rubber line and/or caliper.
The rubber line gets soft and won't release the caliper completely causing drag.
Check to see if the rotor is hotter than the one on the other side.
What happens is the brake fluid goes to the caliper but doesn't release. Kinda like blowing through a plastic straw pinched between your fingers. With some effort, you can blow through it, but there's no way you can suck air back in.
