caliper or common to have a rubber hose inner liner to calapes.jack up frone end hit brakes let up try to turn tires.one will turn hard. crack bleeder loose if pressure releases and tire rolls.rubber line is shot.
The rubber line gets soft and won't release the caliper completely causing drag.
Check to see if the rotor is hotter than the one on the other side.
What happens is the brake fluid goes to the caliper but doesn't release. Kinda like blowing through a plastic straw pinched between your fingers. With some effort, you can blow through it, but there's no way you can suck air back in.
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
