Old 08-01-2013, 11:54 PM
2011RamCC 2011RamCC is offline
Vehicle: 2011 Dodge Ram
Trim Level: Bighorn
Color: Dark Brown
2011RamCC is on a distinguished road
Exclamation Puddle lights
Those little lights under the side view mirrors, is it unusual for those to stop working? The driver's side on my truck doesn't work any more. Are these difficult to replace?
Old 08-02-2013, 07:38 AM
Asur Asur is offline
Vehicle: .
Rep:4364
I have read that the older models had issues with these LED units, go see your dealer it should be under warranty. They will probably tell you that they will replace the whole mirror, but I also read here "somewhere I can't locate it" that they can replace only the unit, but again, your truck is still under warranty, I would just go get it replaced. Call them before hand so they can have the parts handy.
Old 08-02-2013, 11:32 AM
Trim Level: Bighorn
Color: Dark Brown
OK, will do, and thanks.
Old 08-02-2013, 01:59 PM
Huntsvillian's Avatar
Huntsvillian Huntsvillian is offline
Vehicle: 2012 Ram 1500
Rep:15
Huntsvillian is on a distinguished road
Check out this thread:
http://www.ramforumz.com//showthread.php?t=148495
I just had mine replaced under warranty on a 2012, they replaced the whole mirror, but you can buy just the puddle light and there are links in that thread showing you how.
Old 08-02-2013, 05:22 PM
BlueX6 BlueX6 is offline
Vehicle: 2011 Dodge Ram Sport
Color: Hunter Green Pearl
BlueX6 is on a distinguished road
Had both of mine replaced a year ago on warranty. Right side lamp part # 68087238-AA and left is 68087239-AA.
Old 08-02-2013, 11:42 PM
Trim Level: sport
Color: green
Rep:621
sounds expensive if you are out of warranty.
Old 08-03-2013, 01:47 PM
Trim Level: Bighorn
Color: Dark Brown
Unfortunately, I am out of warranty.
Old 08-03-2013, 01:50 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
they are a bitch to get out hence why i painted mine black how are you out of warranty i have a 2011 and im still under warranty
Old 08-03-2013, 01:52 PM
Vehicle: .
Rep:4364
Must be a millage thing, ya I agree they must not be easy to replace, would like to know the procedure at some point, I am guessing mine will do the same at some point also.
Old 08-03-2013, 01:55 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
NOTE: The Light Emitting Diode (LED) units and printed circuit board for these lamps are serviced only as a unit with the lamp and lens assembly. If any part of these lamps is damaged or ineffective, the entire lamp assembly must be replaced.
1. Disconnect and isolate the battery negative cable.
2. Remove the mirror glass and case from the mirror housing (1).
3. Remove the three screws (2) that secure the front cover of the mirror to the mirror housing.
4. Locate the latch tab (4) on the lamp housing (3) within the lower, outboard side of the mirror housing.
5. Using a trim stick or another suitable wide flat-bladed tool, pry gently and evenly at the parting line on the outboard side of the mirror between the mirror housing (1) and the front cover to separate them far enough to disengage the lamp rear flange (5) from the lower rim of the mirror housing.
6. It may be necessary on some vehicles to gently pry between the forward flange of the lamp housing and the mirror front cover to release the strip of adhesive-backed foam weather seal (4) affixed to the forward flange of the lamp from the inside edge of the mirror front cover.
7. Reach inside the lamp housing and depress the latch on the lamp housing toward the vehicle to disengage and lower the lamp assembly from between the mirror housing and the front cover.
8. Pull the lamp assembly away from the mirror housing far enough to access and disconnect the mirror wire harness connector (3) from the lamp connector receptacle and remove the lamp
