Headlight issues - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-02-2013, 02:44 PM
BC18471's Avatar
BC18471 BC18471 is offline
Vehicle: 2011 Dodge Ram
Color: Gray
Rep:38
BC18471 is on a distinguished road
Default Headlight issues
So, a few nights ago I noticed that the passenger side headlight (hi and low beams) are not working. This leads me to believe that it is not the bulbs as I find it hard to that both would go out at the same time. I would assume that the fuse would control both sides and not just the passenger side. I am trying to get ideas so I know what to hopefully look for when I start on it. I did mess with the wiring a while back when I added switchback turn signals, so possibly a ground got screwed up...?
Any comments would be appreciated!
Thank you,
Brian
Custom Katzkin leather, Magnaflow 14" with Y, Mopar CAI, Moroso Catch Can, 180* t-stat, Switchback Front turn signals, All LED lighting, Kenwood DNX6180, Cabin air filter, Smoked Tails and 3rd, Audiovox backup camera
Old 08-02-2013, 11:48 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i would start checking your wiring and go from there.
Old 08-02-2013, 11:55 PM
Arth's Avatar
Arth Arth is offline
Vehicle: 2006 Chevrolet Avalanche
Color: Bronze Alloy Metallic
Rep:2035
I have seen this pop up a few times now and almost everytime it was the ground on the headlight wiring harness to blame.
Pull the headlight and try pushing that pin back into it's slot and see if that fixes it.
Chrome... in moderation.
Old 08-05-2013, 01:32 PM
RLabbe RLabbe is offline
RLabbe is on a distinguished road
Had the same problem with mine. Check your ground and ALL the pins in the plug. If that doesnt work follow your wiring harness and make sure any grounds are tight. I fixed mine a couple weeks ago by tightening up grounds and that did the trick. Be prepared, if you have power locks, your actuators will be going out next. At least, that is what I'm dealing with now. From what I can tell it's a wiring issue that they have bullitens out for but, no recall.
Old 08-05-2013, 03:20 PM
BC18471's Avatar
Color: Gray
Rep:38
Thank for the input! I didn't find the cause of the problem, but it had to be a grounding issue or a bad connection. I pulled the headlight out and then it started working. I was thinking that I might have left a ground wire exposed when I added the resistors for the switchbacks, but everything looked ok and they have been working since last Friday.
Interesting, good to know that it is a known issue and not just me I guess...
Old 12-13-2014, 05:10 PM
crustyp crustyp is offline
Vehicle: 2011 ram
Trim Level: longhorn
crustyp is on a distinguished road
I am having the headlight problem... had the doorlock actuator change the driver side one
on a 2011 longhorn and it's really hard to change it...
