Old 08-12-2013, 06:52 PM
11silverslt's Avatar
11silverslt 11silverslt is offline
Vehicle: 2011 ram slt quad cab
Color: bright silver
Rep:19
11silverslt is on a distinguished road
Default Replacing stock res radio
Thinking about replacing my stock res radio with an Alpine INE-S920 HD nav radio. Anyone do this or have this radio. Any comments or advice is always appreciated .
Old 08-12-2013, 08:51 PM
ajd76's Avatar
ajd76 ajd76 is offline
Vehicle: 2010 Dodge Ram 1500 CC
Trim Level: Sport 4x4
Rep:103
ajd76 will become famous soon enoughajd76 will become famous soon enough
Have you searched for posts regarding radio replacement yet? I only ask because Dodge stereos are 1.5(ish) DIN. Your Alpine is a double DIN which means there will be some fit issues which will require you to alter your dash a bit.
Mopar bed rails, Mopar chrome fuel door, Mopar mud flaps, Mopar door sill protectors, Mopar electronic tailgate lock, Ram LL leather shifter, DeeZee tailgate assist, Access tonneau cover, cabin air filter mod, Magnaflow Y-pipe, & Westin Platinum oval nerf bars.
Old 08-12-2013, 08:58 PM
Rep:19
I am aware of the mod to the sub dash and was thinking of getting radio from Crutchfield, they include all parts necessary and a wiring harness with purchase..
Old 08-12-2013, 11:41 PM
ajd76's Avatar
Rep:103
Yeah, they're great to work with. Personally, I was a little squeamish about cutting the sub dash, so I just bought and installed an RBZ radio instead.
Good luck with your install!
Old 08-13-2013, 03:41 PM
Rep:19
Thanks for the input.
Old 08-19-2013, 08:40 PM
fivehead fivehead is offline
Vehicle: 2011 Ram 1500
Color: Gold
fivehead is on a distinguished road
Hi 11silver,
I put a INE-S920HD in my 2011 Bighorn. I used a metra mounting kit for the dash trim, and used a dremel to cut the bottom piece of plastic sub-dash. It cut out like butter, and took about 15 minutes. I also made two small slices in the metal frame inside, so I could bend the metal back a little bit. At first I was scared to be carving out my truck, but I took the plunge and it turned out to be easy.
Old 08-19-2013, 08:52 PM
BryBry13's Avatar
BryBry13 BryBry13 is offline
Vehicle: 2012 Ram 1500 Express
Color: Mineral Gray Metalic
Rep:33
BryBry13 is on a distinguished road
It will look something like this (Radio I put in is a Pioneer) with the metra trim kit. Trimming the dash isn't that bad. A Dremel is a wonderful tool to use.
Smitty Built Cab Length Nerf Bars, Wade SureFit Mats, LED License Plate & Interior Bulbs, Upper and Lower Billet Grille Inserts, Debadged, Pioneer AVH-X5500BHS, Boyo Back-up Cam, Flowmaster Super 40, Flowmaster 5" Tips, DB-ALL Remote Start, Mcgaughy's 2" Rear Drop Coils, Chrome Brake Painted Drilled & Slotted Rotors, Power Stop Ceramic Pads, MGP "RAM" Caliper Covers, 22" Dolce DC-46 Wheels, Nitto NT420s 305/45R22 Tires ........... So Far............
Old 08-19-2013, 09:39 PM
Rep:19
Thanks guy's I am a little hesitant to cut up the truck, but I cant afford a new 48,000 sport with all the toys so.............. chop chop.
Old 08-19-2013, 10:14 PM
mgbighorn mgbighorn is offline
Color: True Blue
Rep:50
mgbighorn will become famous soon enough
i just picked up an ren radio, i know it dosent have nav but it was the best $300 i spent on the truck so far.
after haveing aftermarket heads in other vehicles that never look right i decided to go with a stock unit
