Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 08-02-2013, 11:52 PM
GEN1's Avatar
GEN1 GEN1 is offline
Vehicle: 1993 Dodge W350 Dually Flatbed
Color: many, camo, black, red,
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
GEN1 is on a distinguished road
Default 93 ram RPM/Voltage issues
Has anyone ever seen the issue of the rpm guage dropping dwn to 0, and at the same time the battery voltage starts to drop also, as soon as the RPM guage starts "marking" the voltage starts to go back to normal? Any help will be greatly appriciated.
Old 08-03-2013, 02:13 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
it almost sounds like your loosing power to the gauges. never heard of something like this.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 08-04-2013, 11:56 AM
GEN1's Avatar
Yeah, I know it sound weird, but it happens every time consistently, the rps drop to 0, and then the voltage starts to drop. sometimes for 10 seconds, sometimes up to 20 mins. doesn't matter if it is sitting idle or doing 60 down the road. I spent some time yesterday looking for a loose connection, didn't find any. Is it possible the crank sensor is going bad, I'm assuming that is where the rpm's are being measured. Here is the pic of the sensor http://www.oreillyauto.com/site/c/de...d=crank+sensor Although I still don't see how it would affect the voltage the way it does, any info would be helpful.
Old 08-19-2013, 10:07 AM
GEN1's Avatar
Update: I solved the issue, turns out that the alternator was "going" bad, had it tested, and was "good", but just barely making the mark to be good, fortunately the tech was paying attention to the numbers, and said it would go bad in a short amount of time, and since it was still under warranty he went ahead and replaced it, upon verifying my information for the vehicle, he noticed that the alternator the truck called for was not the one I had in the truck. the one I had in the truck was for a gas engine, not the diesel, which was a little aggravating, since "they" were the ones who gave me that alternator less that a year ago. Anyway, the diesel one needs the 120 amp, the gas I believe is only about 80/90 amp. So, in theory the alternator could not keep up with the demand and would ultimately "give out" and cause the RPM gauge to drop and the voltage also to drop, since it was not putting out anything, and the truck was just running off the battery at that point. I installed the correct alternator, at first, the rps were still at 0, and voltage low, I then adjusted the gap on the speed sensor (which I had replaced with a new one thinking it was the issue) and the rpm's read normal and the voltage jumped up to normal. From what I understand, the voltage is regulated by the pcm/ecm, which uses the engine speed sensor to verify the engine is running, which in turn tells the alternator to put out more volts?, In my case, the ess was good, but the alternator seems to have shorted a diode and was no longer putting out any voltage.
