Old 08-03-2013, 01:09 AM
misfit1981's Avatar
misfit1981 misfit1981 is offline
Vehicle: 2012 Ram 1500 Quad Cab 4x4
Color: Silver PS2
Rep:45
misfit1981 is on a distinguished road
Default Door trim - can't put back on. Help!
I removed the interior door trim to install new side view mirrors. The trim panels came off just fine. But getting them back on is proving difficult. My wife and I struggled for 15 minutes or so and are not able to get all the hooks to line up with their slots at the same time. Get one side and not the other. I tried muscling it and caused damage to one of the bottom hooks. So I gave up and will try again in the morning. If anyone has any tips or suggestions I would appreciate it!
Thanks in advance!
2012 RAM BH quad cab. Had tow mirrors, just switched to the standard (tour signal) mirrors.
"To be prepared for war is one of the most effective means of preserving peace." -George Washington
Old 08-03-2013, 09:05 AM
Grubrunner's Avatar
Rep:3883
See if reversing the steps from the link below, or just the link itslef, helps -
http://www.paulstravelpictures.com/D...ide/index.html
Grub out!
Old 08-03-2013, 09:22 AM
jd69627's Avatar
jd69627 jd69627 is offline
Vehicle: 2011 Dodge Ram 1500
jd69627 is on a distinguished road
there is a popout around the door handle. pop that out then it just slides in.
Jba headers, Moe's 87mm Throttle Body, Corsa Catback Exhaust, K&N CAI, 180 Tstat, BT Catch Can,
Old 08-03-2013, 03:38 PM
misfit1981's Avatar
Color: Silver PS2
Rep:45
So my GoogleFoo has provided me with a 'for dummies' instructional video!
Once I remove the door handle plate the trim went on without any problems. Thanks for the info!
Old 08-03-2013, 04:39 PM
Grubrunner's Avatar
Rep:3883
Awesome link.
Thank you.
Grub out!
Old 08-05-2013, 03:19 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
Yep -- I had the same problem the first time. They come off easy enough, but I always remove the door handle surround, and switch panel prior to putting back on.
