Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Chassis - Drive Line - Suspension - Wheels and Tires - LEVELING
MOPAR DECALS
Old 08-03-2013, 01:21 AM
hemitrx4's Avatar
hemitrx4 hemitrx4 is offline
Vehicle: 2008 Dodge Ram Quad Cab
Trim Level: TRX4
Color: Black Crystal Pearl
hemitrx4 is on a distinguished road
Default BDS leveling lift?
The bds suspension website says that you can`t properly lift the front of a truck 2" with a single spacer because it will make the ball joint the droop limit and this will cause premature wear or failure. BDS makes a strut spacer that fits within the limits of the factory ball joint angles and adds the additional lift from a strut pre load spacer. The extra preload puts more pressure on the tire/wheel combination to keep it in contact with the road.
Is there any truth to this or are they just blowing smoke? If I lift it 2" wouldn`t the ball joint angle be the same no matter how it was lifted whether it be a spacer at the top and bottom or just one at the top?
