Old 08-03-2013, 01:31 PM
Supraman9291 Supraman9291 is offline
Vehicle: 2001 Dodge Ram
Supraman9291 is on a distinguished road
Arrow Common problems for 2001 5.2L Ram?
I'm thinking about getting a 2001 5.2L Ram from craigslist. Are there any common/major problems from these trucks? Also are there any recommendations for better trucks/engines if there are common problems? Thanks.
Old 08-03-2013, 07:42 PM
wolfman01 wolfman01 is offline
Vehicle: 2013 Ram 1500 QC 4x4
Trim Level: Bighorn Edition
Rep:126
wolfman01 will become famous soon enoughwolfman01 will become famous soon enough
I am not sure if the full size trucks used the same heater controls as the Durango and Dakota twins or not. I would check them out to make sure that the directional control worked correctly. I had this fail on my Durango, and my friends failed on his Dakota. Mine was a 2000, and his was a 2002. This part is no longer able to be replaced with a new one. The magnum engines are pretty solid, and you'll only really have to mess with the typical Chrysler quirks from back then. Dodge still had a pretty bad reputation for their transmissions then, so records of regular service would be recommended.
2014 Chevy Spark (3k)
2013 Ram 1500 Quad Cab 4x4 Hemi 8 speed (7k)
2004 Saturn ION Redline (9k)
1995 Tiffin Allegro Bay (46k)
1989 Oldsmobile Cutlass Cierra (97k)
Old 08-04-2013, 11:46 AM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
the 5.2 is very desirable in some of the older grand cherokees. "zj" i would research the reliability of the trans from that year.
