Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 08-03-2013, 03:39 PM
89powerram's Avatar
89powerram 89powerram is offline
Vehicle: 2004 dodge ram 1500 hemi 4x4
Trim Level: Slt
89powerram is on a distinguished road
Default Dragging brakes
I unhooked my ebrake cause I thought it was the cause but at low speeds I can feel my driver side brake or ebrake drag can anybody help
-IF YOU CANT DODGE IT RAM IT!!!!
Old 08-03-2013, 05:34 PM
HemiLonestar's Avatar
Rep:280
Sounds like you have a sticking caliper. If so, 2 choices, rebuild or replace.
"Big Red"
2006 Charger R/T
Old 08-04-2013, 09:03 PM
89powerram's Avatar
Trim Level: Slt
Had a sticking caliper and ebrake replaced caliper brakes are amazingly better and I adjusted the ebrake to the loosest setting and now I have a abs and brake light on please help
Old 08-05-2013, 03:15 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
check the wires to the sensors on the calipers you replaced. maybe they aren't plugged in or you have a cracked wire
Old 08-05-2013, 06:54 PM
Rep:280
What wires to the calipers do you speak of?
"Big Red"
2006 Charger R/T
Old 08-06-2013, 12:55 AM
Rep:68
the wires to the abs sensors on the wheels you changes the calipers on.
Old 08-06-2013, 06:57 PM
Rep:280
LOL the wires don't go to the caliper, they are part of the hub bearing. That's why it is important to know if you have 2 or 4 wheel ABS when you go to replace your hubs. They have nothing to do with the caliper.
Did you lose alot of fluid when you rebuilt/replaced the caliper? Was it bled? If you lost enough, the ABS module may need to be bled (requires diagnostic tool). Also you'll probably need to readjust your e-brake as it isn't supposed to be as loose as you make it sound.
"Big Red"
2006 Charger R/T
Old 08-08-2013, 04:51 AM
Rep:68
i understand the wires go to the hub and not the caliper but it won't cost anything to see if the wires got damaged while working on the braking system that is attached to the hub. something as simple as a slip with a wrench or ratchet when loosening or tightening bolts can hit the wires and cause damage sometimes without even realizing the slip hit the wires. thats what i was meaning. i have done it without knowing and have seen others do it as well and never knew they damaged the wires.
