Old 08-03-2013, 08:26 PM
DWWHemiguy's Avatar
DWWHemiguy DWWHemiguy is offline
Vehicle: 2012 Ram
Trim Level: Express Quad Cab
Rep:37
DWWHemiguy is on a distinguished road
Default Spark plug question and theory
Let me start with the question. Is it really important to change the plugs at 32k as the manual states? I have an 07 Charger R/T and I changed them at 30k and again at 60k. Both times the plugs that came out looked almost new. They are much easier to get to on the Charger. The Ram looks more difficult. My point is that I really believe in proper maintenance, but is 32k overkill?
My theory is that modern engines have a pcm that constantly monitors and adjusts the tune to keep it running efficiently. Back in the day a vehicle would get out of tune and plugs got fouled. I'm not trying to be lazy, but it looks like a harder job than the Charger.
Old 08-03-2013, 08:28 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
its really not that hard. 1-2 hours tops.
best to take the driver side wheel and plastic wheel lining out to access the ones by the brake booster (if the same as on the 3rd gens, I think it is)
I did it in 2 hours and if it was first time every changing spark plugs on any vehicle
Old 08-04-2013, 05:00 PM
BigOrange BigOrange is offline
Vehicle: 2013 RAM 1500
Trim Level: EXPRESS QUAD CAB
Color: BRIGHT SILVER
Rep:17
BigOrange is on a distinguished road
The manual for my 2013 says every 30K... I'm also wanting to know if this is really necessary
Magnaflow 14" SI/DO, No Resonators, K&N Drop-In Filter, De-badged.
Old 08-04-2013, 05:10 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Well if you pull a plug or two from both sides for inspection purposes at the 30K mark, as long as the electrode and ceramic insulation still appear in good condition, I think you will be alright. Theoretically speaking of course.
Old 08-04-2013, 05:11 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
You can go longer without much loss in performance. But I wouldn't go to 60k. Do maybe 50k. Slight loss in performance and mpg may occur. If you drive easy go longer, if you drive hard change them sooner.
Sean
Old 08-05-2013, 01:52 AM
AzHunter's Avatar
AzHunter AzHunter is offline
Vehicle: 2006 Dodge Ram Quad Cab 4x4
Trim Level: LARAMIE QQ 4x4 3.92
Rep:52
AzHunter will become famous soon enough
I did mine today on my 06 that I just bought. It has 100k miles on it and I am guessing the plugs were original. I pulled 0-60 numbers to see the difference.
Old plugs 0-60, temp 89 degrees
10.1 sec
10.1 sec
10.2 sec
New plugs 0-60, temp 94 degrees
9.3 sec
9.3 sec
9.4 sec
As you can see, new plugs make a huge difference. However, I thought the plugs were good for 60k miles, not 30.
If i can kill it with an arrow, I'll eat it.
Old 08-05-2013, 07:13 AM
xtreme's Avatar
xtreme xtreme is offline
Color: Grey
Rep:29
xtreme is on a distinguished road
I'm about to do my wife 2011 hemi durango on Sunday. She is the primary driver. I will post some pics of the plugs.
Old 08-05-2013, 07:33 AM
bran101010 bran101010 is offline
Vehicle: 2011 dodge ram 1500
Trim Level: express
Color: silver
bran101010 is on a distinguished road
I did mine at 32,000 and I am pretty sure they could have went to 50-60,000 easily
Old 08-05-2013, 12:52 PM
02325's Avatar
02325 02325 is offline
Vehicle: 12 Ram 1500 Bighorn SLT
Trim Level: Big Horn SLT
Color: molten red
Rep:29
02325 is on a distinguished road
A co-worker showed me his plugs that had 50k on them. he has a 08 ram hemi. They looked real good. he is a calm driver, but does pull a 28 ft travel trailer with it during the summer.
I am gonna wait til 50k to do mine. I dont drive it hard, and use High quality (shell) gas.
12 RAM SLT Big HORN - GOIN BROKE BUT N STYLE
Old 08-07-2013, 08:38 AM
mrk7878's Avatar
mrk7878 mrk7878 is offline
Color: Brilliant Black Crystal Pearlcoat
mrk7878 is on a distinguished road
Just a tid bit. I am a service manger at a repair facility, most hemis are using a copper regular resistor plug. Champion rc14mcc4. That plugged is rated from the manufacturer to only last 30k. Also if you have a warranty issue that is to be covered under your factory provisions you have to be able to provide proof of plugs being changed every 30. I do agree when I pulled my plugs at 30 and 60 they looked new but for $32.00 for the parts and about 2 hours, I think its justified to do every 30.
