Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 08-04-2013, 06:30 AM
wchnu's Avatar
wchnu wchnu is offline
Vehicle: 2003 Dodge Ram
Color: red/grey
Rep:26
wchnu is on a distinguished road
Default Leveling 03 QC 4x4
New to all this. What does leveling do. Just cosmetic or functional?
"The very atmosphere of firearms anywhere and everywhere restrains evil interference - they deserve a place of honor with all that's good.
George Washington
Old 08-04-2013, 02:03 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
it raises the front end of the truck to be level with the rear so you don't have "rake".
with your '03 you have torsion bars and can actually
crank those up some. safely up to 2-2.5" but no more than that. so you have a "free" level of sorts. it gives you clearance to run larger/wider tires.
Old 08-05-2013, 01:41 AM
wchnu's Avatar
Color: red/grey
Rep:26
I like free. . Do you think 2 is enough. And how hard is that to do?
George Washington
Old 08-06-2013, 03:47 PM
Rep:1900
super easy. 2 would be good to start with. Youtube it. I quickly found many videos on how to do it.
Old 08-06-2013, 04:20 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Just personal opinion here but I would start with 1" and slowly work up from there. Yes, you will want to measure the front and back before you start and then measure the front after each adjustment but you need to depend on your eyes more than your tape measure. A truck that measures dead level front to back will almost inevitably look nose-high.
It is very easy and there are some good vids on Youtube as well as threads about it here on this forum. Couple of tips:
* I would start out with 4-5 complete turns. Best I remember it raises about 1/4" per full turn.
* Pay attention and make sure you turn both bolts the same number of turns.
* Bounce the front end or drive around the block after each adjustment to settle the front end to it's true height.
* Once you get it where you want it, I would get an alignment within a couple of days. This is a must or you will ruin your front tires. This is the only part of the level that costs anything!
Old 08-06-2013, 04:37 PM
Rep:1900
one of the videos says to make a mark on one of the flat sides of the nut, and a mark on something stationary next to it. so you know exactly how many times you made a full revolution of tightening the nut.
Old 08-06-2013, 04:44 PM
Rep:367
Yeah, I've heard or read that too. I personally didn't. I just paid very close attention to the one I was working on and went slow.
A lot of the instructions I have seen tell you to raise the front tires off the ground before you start adjusting too. This may help lessen the tension on the bolts but it's not really necessary. I used a long ratchet (probably a foot and a half) and didn't have any issue turning them. Just make sure you work the front suspension after each adjustment. If you bounce it by hand during your adjustments, make sure you take it for a mile or two drive and recheck before you decide you are done.
Old 08-06-2013, 10:09 PM
wchnu's Avatar
Color: red/grey
Rep:26
Thanks a million guys. Love this place. !!
George Washington
Old 08-29-2013, 07:34 PM
RetiredJeeper's Avatar
RetiredJeeper RetiredJeeper is offline
Vehicle: 2005 Dodge Ram QC
Trim Level: SLT Quad Cab
Color: Blue
RetiredJeeper is on a distinguished road
I cranked mine about 2.5". Trucks almost perfectly level, I work in a shop so did it with an impact lol didnt watch the turns. Just had someone turn um while I measured. When I did it the front was about an 1/8" off from the back and dead even from left to right...it does make the ride a TAD bit stiffer and I've had it done about a year now.
Old 08-29-2013, 07:35 PM
Color: Blue
And diff get an alignment done. It'll throw the camber off like crazy lol
