Transmission stuck in park (gear) and... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 09-08-2013, 07:30 PM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
Default Transmission stuck in park (gear) and...
So my transmission is stuck and park. It turns on fine and runes fine but when i try to put it in gear and shift it from park to drive nothing. Its stuck in park. After I turn it off from my failed attempts I got under the truck. i noticed a distinct "ticking" noise. No idea whats going on....
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 09-09-2013, 08:05 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
Keep in mind that I'm not mechanic, and I'm just guessing here.....
It sounds like the linkage for the transmission may be either in a bind, or just otherwise stuck.
Did you you notice anything that looked like it was out of place, or otherwise just didn't look right while you were under the truck? Are you able to pop the little cover off of the shifter bezel and press the override button/ switch (or what ever you wish to call it) that allows shifting without the ignition being on etc? If so try that..........
good luck and keep us updated
Exco
Bill
Old 09-10-2013, 07:44 AM
Vehicle: N/A
Rep:518
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
What does the dash display show when you shift it out of Park? Does the PRNDL still show "P"? If so, then I suspect your shifter cable is broken or disconnected.
Crawl under the truck and see if you can shift the lever on the trans (driver's side) by hand. NOTE that you should have the parking brake fully applied AND the wheels chocked when you do this! Especially if you're parked on a slope!! Lever on the trans will be all the way REARWARD in Park.
Old 09-10-2013, 12:36 PM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2016 RAM 3500
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
Rep:48
rsg1963 is on a distinguished road
Don't forget to try the release that is tucked away under a little plastic tab near the gear shifter. It is supposed to be used for overiding the brake lockout I believe. Could eliminate that as a possible culprit (The brake lockout that is).
2016 3500 Laramie MC 385/900 with Aisin tranny & 4.10 gears: Bilstein 5100's up front, 20" Fuel rims with 275/65-20 Micheline LTX MS/2 tires, Weathertec Floor mats, 45 gal RDS tank, Hensley TS3 hitch, Billet DEF and Diesel caps, DeeZee tailgate assist, Bull Ring retractable stake pockets, Amp Research steps, hybrid window tint.
Old 09-27-2013, 05:10 AM
rockdoc's Avatar
rockdoc rockdoc is offline
Vehicle: 2010 Dodge Laramie Hemi
Color: Grey with silver trim
rockdoc is on a distinguished road
Yup RSG1963 I believe hit it. Look on your console near the shifter for a little square "plug", pop it out and you can push down the release mechanism with a pencil or whatever, then try to move gear shift. Happens a lot on mine in dead of winter after driving ice roads / bush roads to work and ice, snow, binds the mechanism.
Let us know.
Old 09-30-2013, 07:18 PM
Rep:160
Gents, Thanks for the advice....
As an update: They replaced the shift linkage and i'm good to go again on this matter.
My Mods
