Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 08-05-2013, 07:34 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
astartes, i missed all your threads on this. this is not an uncommon event with jeepers. if you havent already, put your truck in a garage and run some good size dehumidifiers,. set one inside the cab. if you are still having problems after truck has completely dried, you have to check all connections and make sure they dry and rust free.
Old 08-05-2013, 07:37 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
P0685:
Could be any of the following:
- Faulty Engine Control Module (ECM) power relay
- ECM power relay harness is open or shorted
- ECM power relay circuit poor electrical connection
- Faulty (ECM)
P0688:
- Weak battery- Low voltage while cranking
- Faulty Engine Control Module (ECM) relay
- Blown ECM fuse
- Faulty ECM
- ECM harness is open or shorted
- ECM circuit poor electrical connection
Also just happened to see this:
http://www.**************/forums/f25...ircuit-460881/
Didn't read it but might help, same codes as you.
Sean
Old 08-05-2013, 08:05 PM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
jeez man, I really hope replacing the relays will help. I ordered two of them. they were 11 bucks (like i said) anyhow if they dont work im gonna be at a complete loss and have to take it in to a "certified" mechanic or take it to insurance...
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 08-06-2013, 01:38 AM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
As I said before I hope it is the relays as well. It seemed to point that direction. I hope that does fix it for you because I would be at a loss as well.
I hate electrical problems...
Chrome... in moderation.
Old 08-06-2013, 12:12 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Tom...it pretty much tells me that one of the relays is bad because the problem follows it.
When it was in one position it threw one code. When it was in the other position, it threw a different code. I'd think that's why there were two codes.
How long now before you get the new ones...and did you have an autoparts store cross reference it by taking it in there?
Oh, probably one in a junk yard for a dollar.
Just a thought.
Old 08-06-2013, 01:58 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:221
Just a guess, but maybe something got wet under the truck and ruined those relays.
Old 08-06-2013, 02:33 PM
Rep:160
3 more days of agonizing waiting pain...
I tried starting her today and noticed this.... heres a video of it. No its not the truck turning on. it's simply in the 'on' position right before ignition. I notice this clicking noise coming from the fuse box.
here is the video
My Mods
Old 08-06-2013, 02:39 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
dang you have like 2 or 3 of these discussions going.
Old 08-06-2013, 04:39 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
Drive your truck into a pile of rice. Leave it there for 3 days. It works for cellphones, and other small electronics. I hate to say this, but you will have electrical gremlins for some time. You may have to replace the whole fuse box, and everything in it.
Old 08-06-2013, 09:03 PM
Rep:160
Sorry man, my truck is my only motivation in my life
My Mods
