Old 08-04-2013, 04:21 PM
rammin318's Avatar
rammin318 rammin318 is offline
Vehicle: 1994 dodge ram
Color: blue
rammin318 is on a distinguished road
Default 318 build?
Hey guys, im thinking about grabbing an extra engine for my truck and building it as a spare. Any one have recomendations for parts and boring/ stroking to get a nice solid horsepower number? It would be going in a 94 ram 1500 4x4 rcsb. Thanks guys.
Old 08-04-2013, 06:07 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:418
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I was talking to the owner of a beautiful black Dodge Dart pro stocker today, he runs 6.0 sec eighth mile, figured it was a bigblock or hemi car. Owner said he started with a 318 and built it into a 408 stroker. There are a lot of Big Block Chevy guys that get there azzes whooped by the former old 318.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 08-05-2013, 12:58 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
That math doesn't add up. The de facto 4 inch crank would require a .090" overbore on a 318 to get up to 402 (Hensley Performance does this on early blocks after sonic testing). A 406 is typically what one gets with a stock bore 360, and 408 is a 360 with .030" overbore. Don't guess he spilled the beans on his dimensions?
An easy build would be 318 with .040" over and a 4" crank. That'd make a 392.
Old 08-05-2013, 07:45 PM
HemiLonestar's Avatar
Rep:261
408 stroker is 360 based. Were I you I would grab a 360 to start with. Just with stock displacement with bigger bore AND stroke you're ahead of the game (I have always thought the short stroke 318 was a horrible truck/heavy car engine) from the get-go. Then anything you do on top of stock with a 360 is gravy.
"Big Red"
2006 Charger R/T
Old 08-08-2013, 12:59 AM
rammin318's Avatar
Color: blue
what would i need to do for a 360 swap?
Old 08-08-2013, 01:32 PM
Rep:261
The engine and a PCM (don't think you can program that early a PCM witha tuner). Same trans, externally same engine dimensions.
"Big Red"
2006 Charger R/T
Old 08-08-2013, 01:51 PM
anothernewb's Avatar
anothernewb anothernewb is offline
Vehicle: 2013 Laramie Crew Cab
Color: Dark Cherry
Rep:162
anothernewb has a spectacular aura aboutanothernewb has a spectacular aura about
you can bring the good ol 308 to a 383 (and up to 390) I believe with ease, and durability. I've never done that one, but the old 383 demon was a hell of a car/engine combo. add a set of milled down 360 heads and it should be rock solid, and still get some reasonable mileage
I did, however do a stroker kit to my old 'niner. That was lots of fun. It would out climb and out pass just about anything - except for a gas station.
Livin life one truck payment at a time.
Old 08-08-2013, 06:30 PM
Rep:261
Better off starting with bigger bores. 318 stock bore is 3.91" (not even 4") with a short 3.31" stroke. In a heavy vehicle, as the old saying goes, there is no replacement for displacement. Besides which, the 360 was purposely designed for this from the get go: you can't share internal parts with a 318 because the main bore sizes are different (bigger to better handle the loads). You could use your 318 easily, but stock or modified you would be ahead of the game with a 360.
"Big Red"
2006 Charger R/T
Old 10-25-2013, 12:00 AM
Battering Ram's Avatar
Battering Ram Battering Ram is offline
Vehicle: 2001 Dodge Ram 1500
Rep:24
Battering Ram is on a distinguished road
390 stroker, 1.6:1 rockers, .550 lift cam and up, ARP hardware, forged pistons 8.5-9.5:1, turbo. More than enough power.
http://www.campbellenterprises.com/3...roker-kits.php
Riding high in my Ram!
Old 10-26-2013, 03:43 AM
Rep:85
Don't forget the externally weighted torque converter for the 360 Magnum. You can use the 1993-95 360 Magnum torque converter with your 318 Magnum flexplate, or use the 1996-up 360 Magnum torque converter WITH the matching 1996-up flexplate (weight is on the flexplate and bolt patter is different than early Magnum). Or, get your 318 Magnum torque converter weighted to 360 Magnum specs.
