Old 08-04-2013, 05:03 PM
DCollins3208's Avatar
DCollins3208 DCollins3208 is offline
Vehicle: 2005 Dodge Ram
DCollins3208 is on a distinguished road
Default Good/Bad Spark Plug Wire Brands
About to change out the spark plug wires and boots (along with plugs). What brands have you had a good experience with? What brands are a no-no?
Old 08-04-2013, 05:13 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Mopar ones are the best. 270,000 miles on the wires on my 05 RT Magnum, and 190,000 miles on the ones on my Ram. Nary a problem. I run 180F thermostats to keep underhood temps lower, though.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 215,000 miles To Hell and back. 14.2/96 mph NEDW
Old 08-04-2013, 05:59 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
No issues with the 6.1 / 2006+ coils
Old 08-04-2013, 06:33 PM
Impressive, love hearing of the hemis going for that many miles. I was just going to change out the wires and boots as routine maintenance, all cylinders are firing beautifully but now I doubt if I should even change the wires
Old 08-04-2013, 08:02 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
Taylor 10.4mm Thundervolt 50 shorties, had them on my 05 and look a lot nicer that all the criss cross mess with NGK Iridium IX plugs!!!!!!!!!!!!!!!
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 08-04-2013, 08:53 PM
I push the skinny pedal
Rep:3277
I second the Taylor shorties. Better spark on the combustion cycle and there's not much benefit at all to the exhaust cycle burn, which is why it went away in 06.
Kurtis
Old 08-04-2013, 11:41 PM
Thanks for the input guys, I think I may purchase those shorties to clean things up a bit!
