Old 08-04-2013, 09:39 PM
firemarshallvin's Avatar
firemarshallvin firemarshallvin is offline
Vehicle: 2013
Trim Level: Laramie Longhorn
Color: Black Gold Pearl
firemarshallvin is on a distinguished road
Default HID issue
So I picked up a set of HIDS, 55W lows and 35w fogs from retrosolutions. Installed today thought all was good until I took her out at dark to see things. No issues with the lows, they look awesome. The fogs well, a different story. They worked fine after the install but seemed like after they ran for a little bit while driving around they started to flicker and one dropped out. They told me that we needed a relay harness so I installed it. Here's the kicker, they run fun, no flicker and both work when the truck is off and you out them on. Start it up and they start flickering. Clues? One factory plug is not used, but I can't figure on how this affects things really. The relay chatters so not sure if the signal it's getting is messing it up somehow. I'm gonna try touching base with retro tomorrow, and probably check all connections again, but wondering if anyone had same issues. There were resistors on the lows, nothing in the fog harness. HELP!
2013 RAM 1500 Laramie Longhorn - Black Gold Pearl with all the trimmings. HEMI, 3.92, 8-Speed and Air Suspension
Add-ons:
14" Magnaflow, BAK FiberMax Tonneau, Misc Whelen Emergency Lights and Switchpak, 275/60R20 - BFG T/A KO2
Old 08-04-2013, 11:05 PM
MoparMuscleFan MoparMuscleFan is offline
Vehicle: 2008 Dodge Ram SLT Big Horn
Trim Level: SLT Big Horn
Color: Mineral Gray
Rep:17
MoparMuscleFan is on a distinguished road
I had a similar problem with my orcale hid's. I ordered a resistor kit from Hid Nation. Installed the left side as normal, the right side I did have to modify, because the relay harness left the right side factory harness open. All you need to do for the right side is plug the resistor harness into the factory harness, but you will not plug the other end in you will just be looping the resistors into the harness. this will fool the computer into thinking that the harness is still connected, and it should work. It did with mine. You can cut the other plug off if you want, or just tape it off to prevent water intrusion.
If you need help You can email me at moparmusclefan@live.com and I can send you back a drawing of what you ned to do.
Moparmusclefan
Old 08-05-2013, 07:18 AM
Whitey--62 Whitey--62 is offline
Vehicle: 2014 Ram 1500 CC Rambox
Trim Level: Sport 8-speed
Whitey--62 is on a distinguished road
I installed a set of 35w 6000K HID's in the fog lights on my '13 Sport. I started with just the basic kit and found the same issue your having. I put in a capacitor inline on the factory harness to smooth out the power flow to each ballast. This completely solved my issue with flicker.
Old 08-05-2013, 08:13 AM
Vehicle: 2013
Thanks MoparMuscle. Whitey, that's what I think I've come up with too. They had me order a harness kit, but never said that I'd need the cap relay. The lows harness had it with it in the kit. I went and ordered the cap relay that the sell as an option for $10 and just swap it with the standard relay. Hopefully that solves the problem, thinking (hoping) it will. I have an inquiry into them as well, let's see what they say.
Add-ons:
Old 08-05-2013, 08:35 AM
Asur Asur is offline
Vehicle: .
Rep:4373
I am surprised retrosolutions sold you a kit that was not complete and ready for the 2013 ram 1500. Did you ask them to set u up a complete kit or did you buy it off the site's chose your options thingy?
Old 08-05-2013, 09:26 AM
Vehicle: 2013
I guess youcan say a little of both. I emailed them, but then got antsy when they didn't respond right away (I'm going away next week and wanted to get installed this weekend). So I used the details listed on posts here, probably you, to order things. I assembled my cart and order everything but the harness for the fogs. Retro did get back to me shortly after I placed the order for the kits and said that I had to pickup a relay harness for the fogs, but the link they sent me was just for the regular one. I ordered it and was on my way.
So you are aware of this and figure I should've had the cap harness for both then from the beginning?
Add-ons:
Old 08-05-2013, 01:22 PM
Vehicle: .
Rep:4373
Sounds like a plan, you be fixed up eventually. Try not to use your fogs till you get that harness as with flickering they can lock up and you will need to send them back for replacement. Also the trigger when trying to start the ballasts can cause weird stuff to your truck and give off error codes.
Old 08-08-2013, 08:13 AM
Vehicle: 2013
Just for the record and so that others may see it, I received my capacitor relays yesterday and installed last night. Fogs work fine now. So make a note people, if you are going to replace your fogs with HID's, use a cap based relay harness. I also told a my cousin about this who we did HID's on his '09, lows/fogs a few years ago and he's had flickering if he didn't fire them up before the truck started. Swapped the relay and viola, problem solved.
Add-ons:
Old 08-08-2013, 09:59 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Need capacitors for 13 and up on the Fogs, the 09-12 only need them for high and low beam. But they work nicely.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 08-08-2013, 12:39 PM
USAF Long's Avatar
USAF Long USAF Long is offline
Vehicle: 2013 Ram 1500 RCSB
Rep:69
USAF Long will become famous soon enough
Send a message via AIM to USAF Long
I've been wanting to add 35w HID's to my truck at least in the lows if not in the fogs as well.
In my GMC Sierra I don't have fogs, but I added the 9006 35w kit from Xentech. I had to get 40 amp relays and wire them up to each ballast. I mounted the ballasts on the fender wells, and then used the 12+ signal from the factory headlight plug to trigger the relays. Works fine.
Could I do that with this truck or do I have to buy a special harness?
Also what are the bulb model numbers for the fogs?
-Scott Long-
2013 Ram Express RCSB: 5% tint, de-badged doors, muffler delete y-pipe, K&N panel filter.
Best Run: 14.60@96mph with 2.4 60' at Kil-Kare Raceway in Ohio
