Old 08-05-2013, 03:52 PM
jdftwrth jdftwrth is offline
Vehicle: 2013 Ram 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
Color: Bright White w/White Gold stripe
jdftwrth is on a distinguished road
Default Add a couple of 12v outlets in bed of my truck
Hi there,
Got a question, wife and I do a lot of traveling and we occasionally run into things that we can't find where we live in Texas, the problem is getting the stuff home before it spoils.
A neighbor of mine has a 12v frig/freezer in his travel trailer that works real good for him, i would like to put one of those things in the bed of my 2013 ram 1500 laramie longhorn but don't really know how I would go about putting a couple of 12v outlets in the bed of my truck.
anyone have any suggestions?
Thanks,
JD
Whats most important to me...
My Family, My Religion, My Guns and My Country
Old 08-05-2013, 05:45 PM
macabra11's Avatar
macabra11 macabra11 is offline
Trim Level: Big Horn w/8 spd
Rep:23
macabra11 is on a distinguished road
I have always wanted a 12v plug in the bed of a pickup. The truck can have it's own router and internet connection, but I can't plug a toaster into the bed? C'mon!
Old 08-05-2013, 05:51 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
See this thread in the Exterior Mod section:
Installed 12V Power in Truck Bed (How-To & LONG)
woodtoolguy
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected. Remember, going fast costs money, so how fast do you wanna go?
Semper Fi Forever
Old 08-05-2013, 05:59 PM
82corvette's Avatar
82corvette 82corvette is offline
Vehicle: 2012 Ram Crew Rambox
Trim Level: Laramie SLT
Rep:128
82corvette will become famous soon enough82corvette will become famous soon enough
I used a hole close to the right tiedown in my 12. Bought plastic 12 volt plug at Wallyworld & ran a 12 volt wire from trailer connector to it. The Coleman 12 volt cooler will run the battery down in about 18 hours if I forget to unplug it.
Old 08-06-2013, 02:43 AM
madhatr02's Avatar
madhatr02 madhatr02 is offline
MOPAR or no Car
Vehicle: 2014 Ram 2500 HD
Rep:145
madhatr02 will become famous soon enoughmadhatr02 will become famous soon enough
Excellent idea, I put LED's in my bed of my other truck and always worried I would leave them on because of the backflip I couldn't see them. I know being led's and drawing such little power it would take forever to run down the battery but I had being stranded.
Semper Fi,
Kevin
2014 2500 HD
aka "Big Red"
Old 08-06-2013, 09:48 AM
DAA DAA is offline
Vehicle: 2013 1500, CC/6'4", Hemi/8 spd
Trim Level: Longhorn
Rep:352
DAA is just really niceDAA is just really niceDAA is just really niceDAA is just really nice
I've installed 12V outlets in the back of my last couple trucks. I like the marine kind, that have weather sealing.
I also carry an ARB 12V fridge/freezer with me a lot of the time and consider it one of the best things I've ever bought.
One note about wiring a 12V outlet specifically to power a fridge/freezer, make sure and use adequate gage wire. The bed of the truck is a long way from the battery and the corresponding voltage drop can fool a fridge/freezer into thinking the battery is getting low and shutting itself down. I use 10 gage for a run clear from the battery on a pickup, and at least 12 gage for shorter wheelbase rigs like a Jeep. Also note, I'm talking about real fridges, with compressors and voltage sensing controls, not the little 12V coolers from Wally World - they aren't on the same planet as a real 12V fridge/freezer.
- DAA
Old 08-06-2013, 11:37 AM
Grimass Grimass is offline
Vehicle: Ram
Rep:76
Grimass will become famous soon enough
So, wild idea here. You have a Laramie Longhorn which means you have the trailer hitch plug installed. it gets 12v constant. So why don't you pick up one of these:
http://www.amazon.com/Hopkins-20146-...n+trailer+plug
And wire in 12v...
Or, just buy one of these:
http://www.amazon.com/Hopkins-47675-...ch+plug+to+12v
Edit:
After posting this, the second one is a bit scary should it start to rain. I'd rather build my own that I can hella-waterproof.
Old 08-06-2013, 05:39 PM
Thanks for the idea, I had considered patching off the trailer hitch 4 pin connector, but then if I have my fridge/freezer and a trailer connected the overall load on that circuit could cause one or more unexpected problems.
I don't know if the radio in the ram is looking at that circuit or not but that %^*%& radio in the truck is flaky enough without me giving it another reason to take another trip off into never never land.
Old 08-11-2013, 07:13 PM
mrolow's Avatar
mrolow mrolow is offline
Vehicle: 2013 Ram 2500 4x4
Color: Prairie Pearl Clearcoat
Rep:132
mrolow will become famous soon enoughmrolow will become famous soon enough
I plan on adding power outlets at the rear of my Ramboxes. I will be running a 4awg wire from the battery to the rear of the truck for a detachable jumper cable and will tap into the cable run at a wire junction terminal near the rear of the truck. I will then feed the last 5 feet with a 10-12awg wire with a 20 amp inline fuse for each one. I will post pictures when I have it completed.
Mods: Too many to list
Old 09-14-2013, 04:07 PM
mrolow's Avatar
Rep:132
Finally finished putting the Rambox power outlets in place. They were not an easy task as I could barely reach the back of the outlets to put on the nut to hold them in place. Next weekend I will run the power to them from the battery.
