Old 09-15-2013, 09:03 AM
Kevinhville Kevinhville is offline
Vehicle: Ram 1500
Color: Deep Cherry
Rep:27
Kevinhville is on a distinguished road
Here's a friendly piece of advice for guys adding wiring to your truck. Put your fuse at the origination point of your wire. If your wire originates at the battery, put the fuse right at the battery. This way, your entire length of wire is protected. The purpose of a fuse is not to protect the device being plugged in, it's to keep your truck from burning to the ground. The fuse should be sized to protect the wire. Do an Internet search to find the appropriate fuse size for your wire. I work for a company with a large truck fleet, and our most common cause of truck fires is improperly installed aftermarket wiring.
Old 09-15-2013, 12:54 PM
marvin02's Avatar
marvin02 marvin02 is offline
Trim Level: Tradesman QC 4x2
Rep:30
marvin02 is on a distinguished road
Originally Posted by Kevinhville View Post
. . . The fuse should be sized to protect the wire. Do an Internet search to find the appropriate fuse size for your wire.. . .
The fuse should be sized to protect the component that has the lowest capacity. If you only size a fuse by wire size then you may be allowing too much current to another component.
If you need to run multiple items from one run of wire, if you have single fuse it should be sized to protect the lowest rated component. You may need to install multiple fuses in this situation. One at the battery to protect the overall circuit and fuses at each component to protect the individual components.
I do agree that a long run of wire with no fuse protection is a problem waiting to happen.
Old 10-12-2014, 03:59 PM
Silvercreek's Avatar
Silvercreek Silvercreek is offline
Vehicle: 2013 Laramie
Trim Level: Longhorn Crew Cab
Color: White/Gold
Rep:487
Silvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of light
I don't have one now but in my previous truck I installed an auxiliary battery in the bed and used an isolator similar to the one in the picture below. That was you will always have plenty of extra 12 volt power.
"One Small Step For Man, One Giant Leap For RAM Fans"
4th Generation - 2013 RAM Laramie Longhorn
*** US Army Retired - 11B40 - 1964/'85 ***
Old 10-12-2014, 05:56 PM
Rep:2657
I have a direct battery connection that runs to a 4 fuse panel under the hood
The wiring for 2 runs then goes to a convenient illuminated rocker switch panel in the cab, a 3rd run goes to a CB radio, the 4th fuse in the panel is just extra
From the rocker switches the wiring & plastic loom follow the trucks frame back to the left front corner of the bed to a couple of WeatherPack connectors.
From there a ground & power wire go to my auxiliary gas tank & the other 2 wires go to my rotating lights
You can see the CB radio & 2 illuminated rocker switches in this pix
Here you can see the Auxiliary Fuel Tank & Lights
This is the Weather Pack website
http://www.whiteproducts.com/connectors.shtml
