Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-05-2013, 06:17 PM
sailorman sailorman is offline
Vehicle: 2006 Dodge Ram
sailorman is on a distinguished road
Default Vents Intermittent
My vehicle is a 2006 Dodge Ram 2500 with Cummins deisel. When the air conditioner is on I get cold air through the drivers side vents and outside air(warm air) through the passenger vents. When I move the air control switches to different positions I can usually get cold air through the passenger vents.
Any ideas?
Last edited by sailorman; 08-05-2013 at 06:23 PM. Reason: Should have posted in 3rd generation not first generation
Old 08-08-2013, 12:33 PM
Nabby Nabby is offline
Vehicle: 1991 Dodge Ram
Trim Level: Unknown
Color: Blue
Nabby is on a distinguished road
Having read on this common issue, there are a couple things that could possibly be causing this. The more pita of the problems could be blend doors in the vent system not opening and closing correctly, but some people have said that Dodge a/c is a little odd in that you can actually get this problem from being low on refrigerant, which is actually pretty easy to top up, assuming you don't have a leak.
