Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Place your Ad Here!
Old 08-05-2013, 06:43 PM
CB56 CB56 is offline
Vehicle: 2000 Dodge Ram 2500
Trim Level: Laramie SLT
CB56 is on a distinguished road
Default The "no bus" problem
In the relay/fuse box under the hood there is a large square plug with a bolt with a Phillips head in the center. It has a bundle of wires going through the firewall. I took that plug in and out a few times and now every thing is working. I can't say how long it will work but at least something happened. CB
Old 11-24-2014, 03:12 AM
wyomingwelder wyomingwelder is offline
Vehicle: 2001 dodge ram 3500 4x4 5.9 di
Trim Level: n/a
Color: n/a
wyomingwelder is on a distinguished road
cool i will try that tomorrow. will post if it works or if i figure out any more about it.
Old 01-08-2015, 10:59 PM
Trim Level: n/a
Color: n/a
the no buss issue hasnt reocurred however there is a very heavy key-off battery drain now. Unhooked neg.batt. cable attached a test light n series and pulled fuses till I located the problem. My cluster. Will be tearin in to it tomorrow anything in perticular I should be checking first or thoughts on the issue ?
