Old 08-05-2013, 08:23 PM
nater nater is offline
Vehicle: 1994 Dodge Ram 1500
Trim Level: not sure
Color: undecided
nater is on a distinguished road
Default extended cab to regular cab???
so i recently bought an extended cab 98 dodge ram 1500 just for the fact it was a 4x4 and has an running engine but the cab is rotted out to hell but frame is OK now for my ? i have a perfect no rot regular cab truck will the cab directly bolt on to the frame or is the extended cab and regular cab two different cabs completely?
Old 08-10-2013, 04:59 PM
ModifiedBEAST ModifiedBEAST is offline
Vehicle: 99
Color: blue
Rep:20
ModifiedBEAST is on a distinguished road
you can buy an extended cab at a junkyard.
single can would leave a big gap.
Old 08-11-2013, 05:25 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The frames and cab mounts are different between the standard and extended cab vehicles.
You would at minimum have to re-position the two rear cab mounts. Then you would have the opportunity to cut the bulk-head off of one bed and about 2 feet off the other bed and make a single cab with a 10" bed (or 4" if it's a 6" bed).
Unless the extended cab PU is a 6" bed, then you'd have to put the 8" bed on it (And two front mounts). However with the difference in the frames the bed would still have to be modified as the wheel wells wouldn't be centered correctly and the tank (fuel) may have some issues to deal with.
