Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 08-05-2013, 11:10 PM
Lake O Hunter Lake O Hunter is offline
Vehicle: 2004 Dodge Ram 1500 QC 4x4
Color: Gray
Lake O Hunter is on a distinguished road
Default towing vs. highway questions
04 st hemisphere 4wd 35" tire
superchips performance tune and other minor upgrades
I stock gears but do not know the ratio; I am turning about 2k rpms at 70 mph
I tow a boat weekly that weighs approximately 7000# but also drive a lot of highway miles. Ithink I need to re-gear for better towing performance and off highway performance but I am not sure what ratio?
Also will my superchips tuner adjust for gear ratio?
I am open to suggestions and let me know if I need to provide more info. Thanks in advance.
Old 08-06-2013, 01:02 AM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
have you thought about going to the gears in the power wagons? they are 4:56 gears and with the 35" tires but it might raise your rpm's a bit more than they are now. but you will have alot better power towing. and the engine wont work as hard when pulling. best thing to do is see what you have in the truck now before considering a gear change.
Old 08-06-2013, 05:26 AM
Color: Gray
Is there a way to figure it out without pulling the differential cover; I am certainly not opposed to going that low to improve pulling ability and just general acceleration.
Old 08-06-2013, 07:52 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I'm not positive but I assume the 04 rams have the 545rfe, not the 45rfe. If that is correct, then based on the math:
If you had 3.55's with a 35" tire, at 70mph you'd be turning 1598 rpms in the 6th gear
If you had 3.92's with a 35" tire, at 70mph you'd be turning 1765 rpms in the 6th gear
The superchips is able to correct for gear ratio. Do you have it corrected for tire size currently?
You can also request your build sheet from chrysler and it will have your differential ratio.
Sean
Old 08-06-2013, 04:25 PM
Color: Gray
Requested build sheet and checked my rpms today; apparently I drive a little faster than I thought; I was @1600 rpms at 70mph.
Yes I have corrected for tire size using the programmer and truthed it against multiple gps and vehicles.
I would love to see the formula you are using, so I can estimate what it would be with 4.56 or other gear ratios.
Thanks for your help.
Old 08-06-2013, 06:00 PM
snrusnak's Avatar
Rep:1385
RPM = (MPH * Final Gear Ratio * 336) / Tire Diameter
so, in the 6th gear(ratio is 0.67:1):
RPM = (70 * (0.67*4.56) * 336) / 35
RPM = (70 * 3.0552 * 336 / 35
RPM = 2053
Sean
Old 08-06-2013, 06:18 PM
Color: Gray
Thanks again. That doesn't seem unreasonable for highway speed? Plus it would improve towing and city driving aka using less throttle.
With factory tires I would be around 1800 @70mph, correct?
I just substituted tire size of 31 in your formula
Old 08-06-2013, 07:12 PM
snrusnak's Avatar
Rep:1385
With factory tires (31" diameter), and 4.56's, you'd be at about 2318 rpm at 70mph in the 6th gear.
Sean
Old 08-06-2013, 07:13 PM
snrusnak's Avatar
Rep:1385
2000 rpms isn't too bad with 4.56's and 35 in tires. I'd probably go that route if you are keeping 35in tires for the life of the truck. If you plan to go back to a smaller tire I'd get 4.10's.
Sean
Old 08-07-2013, 06:54 AM
Color: Gray
Sorry I meant factory tires and factory gears; i was trying to figure out what the rpms were stock; I don't see me going any higher or lower with my truck; the leveling kit and 35s is the perfect to me, so I think 456 it is...
I greatly appreciate the information.
