New Member Needs Quick Advice - Differential Issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 08-06-2013, 02:00 PM
Seadweller Seadweller is offline
Vehicle: 2003 Ram 1500 Quad Cab
Seadweller is on a distinguished road
Default New Member Needs Quick Advice - Differential Issue
Hi Everyone!
New member...We just bought my son his first vehicle, a 2003 Ram 1500 Quad Cab with Hemi engine and 113K miles...The truck is in spectacular condition for its age, and came with an excellent service history...We test drove it through neighborhoods, so never really got above 40MPH...Fortunately, we bought it from a dealer that offered a 60 day, unlimited mileage warranty...
Driving it home, I noticed a whine that seems to be coming from the rear end at speeds over 40MPH...It whines during cruise or mild acceleration, but stops when you lift your foot off the gas...I spent the better part of last night researching this, and it was an eye opener to see the issues with the 9.25 LSD in these trucks...Of course, I was up all night worrying about it...
I brought it to the dealer, and just spoke to the service writing a hour ago...He said they are "researching the issue, but it's likely normal for a vehicle of this age"...I don't believe there's anything normal about it, and furthermore, the whine will drive you nuts because the frequency cuts right through the stereo...I can't imagine an hour drive with that whine...
I'm guessing it's likely a pinion bearing, but of course I read about the dreaded clutch pack retainer clips as well...I don't believe the dealer has even taken the cover off the differential yet...I also have a 3 day period where I can give the truck back to the dealer, no questions asked, and that expires tomorrow...
What do you guys believe is the issue? I thought of making the dealer an offer; I'll pay for a Detroit DTT, if they install it and don't charge me for labor...I would imagine while the DTT is going in, a rebuild kit would also be in order (bearings, etc.)....
Any advice would be most appreciated, as I'm going to be out of runway soon...
Thanks!
Old 08-06-2013, 02:40 PM
bparsel bparsel is offline
Vehicle: 2014 Ram
Rep:25
bparsel is on a distinguished road
You're spot on with your diagnosis. It IS one of those 2 things :-)
My $$$ would be on the pinion bearing, but there is no way to be sure until they open it up. If its the pinion bearing you're looking at about $500 to rebuild the rear etc if the ring and pinion are still in good shape.
Old 08-06-2013, 03:11 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
If the whine is that pronounced then you are definitely correct about it not being normal. That sounds very shady for the service writer to tell you it was normal. That's BS!!
My guess would be the same. It's very likely one of those two issues. I'm not sure about the procedure for diagnosing a faulty pinion bearing but the clutch pack issue is easy enough to determine by simply pulling the cover. You will either find the clips still in place or swimming around in the diff fluid, possibly in pieces.
I think I would give them the option. Either diagnose it properly and to my standards or take it back. Sounds like a nice truck otherwise so I'm guessing you would rather not give it back but if you keep it as-is, be prepared to foot this bill yourself because it sounds like a certainty.
Old 08-06-2013, 05:59 PM
Thanks guys....
By the way, what's involved with rebuilding this particular differential? Is bearings and seals sufficient, or should the ring and pinion also be replaced? How about the LSD? Does it make sense to replace the seals and bearings and leave the factory LSD in place, or will the clutch pack retainer clips eventually break and take out the rear end?
I'm inclined to see if they'll rebuild the rear end, and throw in a DTT if I pay for the part...That would take care of things for many miles, right?
Old 08-07-2013, 12:41 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
not normal, cant believe they said that.
Old 08-07-2013, 10:02 AM
Vehicle: 2014 Ram
Rep:25
Originally Posted by Seadweller View Post
Thanks guys....
Standard would be Pinion bearings, and inner carrier bearings and seals. Its VERY rare for rear wheel bearings to need to be replaced on these trucks. Its impossible to say whether the ring and pinion, pack, spider gears etc will need to be replaced. Only way to know is to visually inspect them etc.
If they cover the cost of the rebuild then I would go for it. DTT is a great option if theyll agree to install it during the rebuild. In the grand scheme of things a rear end rebuild isnt really that big of a deal.
Old 08-07-2013, 02:57 PM
Thanks everyone...It's pretty frustrating to hear them tell me it’s “normal,” and to add insult to injury, they said they called the nearby Dodge dealer who also told them it was “normal”…I called the Dodge dealer near me who said it was absolutely not normal, so we have this back and forth banter going on…
I went to give them the truck back this morning, and they said they’ll send it down to the Dodge dealer and have the rear end taken care of, whatever it takes, so we’ll see what happens from here…I just hope the Dodge dealer doesn’t stick to their original position that the whine is normal…I asked that they have the Dodge tech call me to discuss the issue once they have the cover off…
Old 08-07-2013, 04:27 PM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
BULL SHIT. It is NOT normal, make them hold their end of the deal on the warranty and fix it.
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
