Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Chassis - Drive Line - Suspension - Wheels and Tires - LEVELING
Place your Ad Here!
Old 08-06-2013, 02:03 PM
dbezzek524 dbezzek524 is offline
Vehicle: 2013 Dodge Ram 1500 Express
dbezzek524 is on a distinguished road
Default '13 Leveling Kit Questions
I have a 2013 Dodge Ram 1500 4x4 and I just recently bought a leveling kit which comes with a 3.5 inch coil spring spacer for the front and a 2 inch rear coil spacer. So I was wondering is it a good idea to install or will it destroy the front end and if it does what will it affect and do I need an alignment after installing the lift? Thanks
Old 08-06-2013, 02:37 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
where on earth did you get a 3.5" spacer??? ebay?
I'd hesitate to install that, your CV angle would be pretty steep I'd imagine.
I'd keep the rear ones and get bilsteins for the front and set at 2.8" if you want to be that high up in the front.
Old 08-06-2013, 02:44 PM
SK-Ram SK-Ram is offline
Vehicle: 2014 Ram
Trim Level: SPORT
Rep:54
SK-Ram will become famous soon enough
3.5" is extreme for a front end level, is it a level + body lift combo?
Old 08-07-2013, 09:32 AM
No its just a leveling kit, the front is actually a strut spacer, is that worse or better at least?
Old 08-08-2013, 09:32 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
3.5" is way too much for the front end of a 4wd truck.... Snap a picture of your CV shaft and control arm angles and post it up. My guess is that they're way too steep.
