Old 08-06-2013, 02:56 PM
anothernewb's Avatar
anothernewb anothernewb is offline
Vehicle: 2013 Laramie Crew Cab
Color: Dark Cherry
Rep:162
anothernewb has a spectacular aura aboutanothernewb has a spectacular aura about
Default reverse tilt mirror settings
I love the tilt mirror function, however one thing is plaguing me. with my last truck you adjusted the mirror position while in reverse, and it stored that position and returned to it when in reverse.
However, with the ram, it always returns to it's preset position, which is not optimal for me. Haven't found anything in the manual regarding setting it either. perhaps I need to be adjusting it and saving it with the seat memory?
Livin life one truck payment at a time.
Old 08-06-2013, 04:45 PM
Monster5601 Monster5601 is offline
Vehicle: 13 Laramie 1500, 15 Longhorn
Color: Cherry Red
Rep:470
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
If you get that to work let me know. I have yet to find away to select a custom setting.
Old 08-06-2013, 10:53 PM
DrAudio DrAudio is offline
Vehicle: 2013 Ram Sport 1500 ordered
DrAudio is on a distinguished road
Mine don't tilt at all. Is it a setting somewhere or not available on sport?
Old 08-06-2013, 11:24 PM
Bhbdvm's Avatar
Bhbdvm Bhbdvm is offline
Vehicle: 2015 Ecodiesel Crew Cab 4x4
Trim Level: Outdoorsman with 6.4
Color: Prairie Pearl
Rep:29
Bhbdvm is on a distinguished road
Go to driver asst. screen in 8.4 screen in settings. There is a box to check for this option.
Old 08-06-2013, 11:28 PM
brian-nicola brian-nicola is offline
Vehicle: 2013 RAM Laramie 1500
brian-nicola is on a distinguished road
Same here, drivers mirror tilts all the way down, passenger mirror 1/2 tilt no way to change it. Can't save in settings 1 or 2 as vehicle doesn't want to save in reverse. Maybe RAM thinks it is right hand drive? The passenger mirror should tilt all the way down to see the curb. Dealers problem at first service along with "memory system unavailable vehicle not in park" constantly flashing up....
Old 08-07-2013, 12:21 AM
bigbody's Avatar
bigbody bigbody is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Black/gray
bigbody is on a distinguished road
Yes I wish you could adjust them and they would stay, I think they are defaulted so you can see the tires. I too have been having the memory system unavailable vehicle not in park message after the recent bcm flash, dealer reflashed my truck and hasn't popped back up yet hope it doesn't. One back
2013 RAM 1500 Laramie, sunroof, 3:55gears, undercover se, avs in channel, 30% tint all around
Old 08-07-2013, 10:01 AM
KJ48 KJ48 is offline
Vehicle: 2014 1500 Ram QC
Color: Blue Streak pearl
Rep:117
KJ48 will become famous soon enoughKJ48 will become famous soon enough
my '10 and '12 you couldnt save either, was hoping they changed it for '13 but its still the same and you cant adjust where the revere tilt ends up.
I only really used it when backing my trailer in the driveway, so I just turned the reverse tilt off and used the the #2 memory to adjust the mirrors, that way the mirror woudnt keep going back and forth when backing and pulling forward the trailer.
Old 08-07-2013, 10:06 AM
Color: Dark Cherry
Rep:162
Grrrr... figured it might be a fixed position thing.
Oh well, the mirror position has to be hard coded in a memory block somewhere in the program. Perhaps I should blow a ton of money and find a programmer who can hack the code and change it to remember last set position. Selling the code might prove somewhat lucrative.
Old 08-07-2013, 10:23 AM
Pckrfan's Avatar
Pckrfan Pckrfan is offline
Vehicle: 2014 Ram 1500 Crew Cab
Pckrfan is on a distinguished road
I am pretty sure that is just an enable or disable setting.
Old 08-07-2013, 12:23 PM
DarthRam's Avatar
DarthRam DarthRam is offline
Join the Dark Ram Side!
Rep:1543
I thought this was an option on certain trims only and not on Sports. On my 8.4a the only thing under driver assist is Hill Assist
Edit: I guess it only comes with the memory seats?
