Supercharging on stock motor - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 08-06-2013, 09:33 PM
Grubrunner's Avatar
Rep:3883
I loved it!
Much truth....
Grub out!
Old 08-07-2013, 08:07 AM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
I've looked at sharadon I think is the name transmissions anyone used them? Also if I'm installing a boost gauge and air fuel where are they tapped into?
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 08-07-2013, 09:41 AM
Rep:3347
Sharadon does make an aftermarket transmission and they have one behind a truck making BIG numbers, but they're not known for street reliability; the same can be said for the ATS trans. It's easy to build a trans that will hold power at the track, daily driving is where our problems really come to a head. The MGH trans has been holding up well behind several trucks that are daily drivers, so only time will tell with them. I've had one behind a stock engine for over 4000kms so far and we'll see how it holds up to the forged engine +12psi that I just finished installing.
Boost gauge is installed into a vacuum line unless you install a separate vacuum pump, then you install it onto a barb fitting on your intake manifold. The A/F gauge is just an oxygen sensor installed into the exhaust system before the cat. You should install it after the merge collector.
Old 08-07-2013, 09:42 AM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
Boost taps into vacuum line, wide band needs a bung welded to the exhaust
...best place on a 4G is drivers side down pipe just before the cat.
edit: Dammit, Kurtis beat me to it lol
Old 08-07-2013, 11:55 AM
Color: RED<----
Rep:15
What cats?? Haha thanks for all the info. Anyone know the gains on stock motor? A guesstimate
Old 08-07-2013, 12:24 PM
Color: RED<----
Rep:15
Also, how does the stock fuel pump hold up?
Old 08-07-2013, 12:46 PM
Rep:561
It doesn't
an Aeromotive 340 Stealth pump will solve that for about $170 though,
Mine was just ordered yesterday, My dyno guy wont run my truck until I get one installed
http://aeromotiveinc.com/products-pa...-inlet-inline/
With a Ripp kit on 4G Hemi, my bud picked up 170HP
...went from 320 to 490 whp
It will def go higher with a better fuel pump,
HP was still climbing when we shut her down when it started running out of fuel at the top end after 5500 rpm
Old 08-07-2013, 04:29 PM
Color: RED<----
Rep:15
It doesn't
Damn that's impressive gains. How many psi was he running?
Old 08-07-2013, 04:33 PM
Color: RED<----
Rep:15
It doesn't
I looked up the applications on the link I didn't see dodge Ram, will it work for ours?
Old 08-07-2013, 04:46 PM
Rep:561
I think he was at about 7 PSI,
Still room for a little more once we install our Water/Meth kits.
11142 is the right pump for our application,
according to my tuner, not sure its the same for a 3G Hemi (probably is)
