Old 08-06-2013, 09:59 PM
Vdubbry Vdubbry is offline
Vehicle: 2013 RAM 1500
Vdubbry is on a distinguished road
Default Help SOS - Radio screen blank!
Hey all,
I was starting to do some pre-wire for the system I plan to install on my (8.4A - No Alpine). I was tapping the speaker level wires so I could add a clean sweep and realized I should disconnect the battery to be safe.
So I did, tapped the lines etc, re-connected and no screen at all. There has to be a fuse or something I messed up, the stereo was working just fine minutes before. I found no fuse for Radio in the manual.
I tried jiggling all the wires in to the harness that plugs in to the radio, I disconnected where I tapped the speaker levels, triple checked that what I did tap was in fact the speaker wires. Not sure where else to go other than the dealer.
What could have happened?
Old 08-06-2013, 10:24 PM
Update - Resoloved. I found that the radio has a fuse separate of the entire system. It's a 20A fuse you have to follow the wire running from the battery and it's in a protective rubber casing.
Thanks
Old 08-07-2013, 05:03 PM
plumcrazy73's Avatar
plumcrazy73 plumcrazy73 is offline
Vehicle: 2013 Ram 1500 2WD Crew Cab
Trim Level: SLT w/Big Horn EQ GP
Color: True Blue Pearl
Rep:119
plumcrazy73 will become famous soon enoughplumcrazy73 will become famous soon enough
so what was involved with putting a clean sweep in?
Old 08-07-2013, 05:41 PM
So far its not too bad. I had already tapped the front channel and ran it to a nice Audio Control LC2i which I put under the drivers seat so I could run a sub, so I just had to tap the rear channel and ran that to under the seat as well. Now I have front/rear sent in to the JL Clean Sweep.
I already had power and ground under the seat as well for the LC2i. Now I need to run speaker wires from all 4 doors so I can run aftermarket speakers and an amp and get rid of running them off the crappy head unit power.
I've been doing it in phases since I have had a crazy work schedule. Fingers crossed she turns out good!
