Old 08-09-2013, 10:36 PM
semlohde's Avatar
semlohde semlohde is offline
Vehicle: 2014 RAM Laramie LongHorn Mega
Trim Level: LaramieLongHorn Mega
Color: bright white
semlohde is on a distinguished road
I have a post in the general area, threw a code for the transmission. My light came on at 65 miles, I had the truck 18 hours. They claim to have a new transmission coming after 2.5 weeks due in the 13th Aug. Not EVEN looking for any engine problems!
Old 08-12-2013, 10:54 AM
BeaverNation BeaverNation is offline
Vehicle: 2013 Dodge Ram 2500
Trim Level: ST Crew Cab
Color: Gray
BeaverNation is on a distinguished road
This happened to my 2013 Diesel as well. I took it out to freeway headed to the airport to pick up my parents...like came off. I didn't go into the dealership. It happened twice on my dads 2008 Ram Diesel and both times, took it to the freeway, cruised around 70 for a few miles and eventually the light came off.
Pretty much the truck was made to drive and not drive in the city. The Prius was made to drive to the store, the Ram Diesel was built to tow a big @ss trailer and blow coal....but i still prefer to drive the Diesel to the store!
Old 01-15-2015, 08:01 PM
DrX DrX is offline
Vehicle: 2014 Ram 2500 4x4
Trim Level: Laramie LTD
DrX is on a distinguished road
My 2014 popped the P24E2 today, or at least I just noticed the CEL. Cleared it....will see if it comes back. What little I can find online says that it is "ammonia sensor" related. Not a big fan of this urea system in the frozen north. The solution spends more time as a solid than a liquid.
2014 Ram Laramie 4X4 2500 CTD
Old 01-15-2015, 09:13 PM
RayK RayK is offline
Vehicle: 2014 Ram 2500 Laramie
Rep:72
RayK will become famous soon enough
Since Updated my Insight CTS today for my RAM, I noticed EDGE has a complete list of all the codes. P24E2 is not listed.
Here is the P24* codes.
P2400 EVAP Emission Sys Leak Detection Pump Ctrl Circ/Open
P2401 EVAP Emission Sys Leak Detection Pump Ctrl Circ Low
P2402 EVAP Emission Sys Leak Detection Pump Ctrl Circ Hi
P2403 EVAP Emission Sys Leak Detection Pump Sense Circ/Open
P2404 EVAP Emission Sys Leak Detection Pump Sense Circ Range/Perf
P2405 EVAP Emission Sys Leak Detection Pump Sense Circ Low
P2406 EVAP Emission Sys Leak Detection Pump Sense Circ Hi
P2407 EVAP Emission Sys Leak Detection Pump Sense Circ Interm/Erratic
P2408 Fuel Cap Sens/Switch Circ
P2409 Fuel Cap Sens/Switch Circ Range/Perf
P2410 Fuel Cap Sens/Switch Circ Low
P2411 Fuel Cap Sens/Switch Circ Hi
P2412 Fuel Cap Sens/Switch Circ Interm/Erratic
P2413 Exhaust Gas Recirculation Sys Perf
P2414 O2 Sens Exhaust Sample Error Bank1 Sens1
P2415 O2 Sens Exhaust Sample Error Bank2 Sens1
P2416 O2 Sens Signals Swapped Bank1 Sens2 / Bank1 Sens3
P2417 O2 Sens Signals Swapped Bank2 Sens2 / Bank2 Sens3
P2418 EVAP Emission Sys Switching Valve Ctrl Circ /Open
P2419 EVAP Emission Sys Switching Valve Ctrl Circ Low
P2420 EVAP Emission Sys Switching Valve Ctrl Circ Hi
P2421 EVAP Emission Sys Vent Valve Stuck Open
P2422 EVAP Emission Sys Vent Valve Stuck Closed
P2423 HC Adsorption Catalyst Eff Below Threshold Bank1
P2424 HC Adsorption Catalyst Eff Below Threshold Bank2
P2425 Exhaust Gas Recirculation Cooling Valve Ctrl Circ/Open
P2426 Exhaust Gas Recirculation Cooling Valve Ctrl Circ Low
P2427 Exhaust Gas Recirculation Cooling Valve Ctrl Circ Hi
P2428 Exhaust Gas Temp Too Hi Bank1
P2429 Exhaust Gas Temp Too Hi Bank2
P2430 Sec Air Inj Sys Air Flow/Press Sens Circ Bank1
P2431 Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank1
P2432 Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank1
P2433 Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank1
P2434 Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank1
P2435 Sec Air Inj Sys Air Flow/Press Sens Circ Bank2
P2436 Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank2
P2437 Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank2
P2438 Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank2
P2439 Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank2
P2440 Sec Air Inj Sys Switching Valve Stuck Open Bank1
P2441 Sec Air Inj Sys Switching Valve Stuck Closed Bank1
P2442 Sec Air Inj Sys Switching Valve Stuck Open Bank2
P2443 Sec Air Inj Sys Switching Valve Stuck Closed Bank2
P2444 Sec Air Inj Sys Pump Stuck On Bank1
P2445 Sec Air Inj Sys Pump Stuck Off Bank1
P2446 Sec Air Inj Sys Pump Stuck On Bank2
P2447 Sec Air Inj Sys Pump Stuck Off Bank2
Old 01-15-2015, 09:27 PM
DrX DrX is offline
Found this on another forum:
" The P24E2 code is related to the Ammonia Sensor Circuit Performance, however for more detail I would recommend you have the vehicle inspected by a Dodge dealer. Seeing as your Ram is a 2013 depending on the metrage, the vehicle should have warranty coverage for factory defects.
Additional technical information can also be provided through a service manual, which is available for purchase at:
https://www.techauthority.com/en-US/Pages/Home.aspx
Please let me know if you have any questions or would like additional assistance reviewing with a Dodge dealer and I'd be happy to help! [IMG]http://www.**************/forums/images/smilies/smile.gif[/IMG]
Dave P.
Top Care Specialist
Chrysler Canada "
Old 01-18-2015, 01:46 PM
DrX DrX is offline
Some more info on ammonia sensors, which operate in the exhaust stream in a similar manner to O2 sensors.
https://www1.eere.energy.gov/vehicle...eer07_wang.pdf
Reading other forums, this seems to be a fairly common issue on these trucks.
