Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 08-07-2013, 02:32 PM
blacklaramie98 blacklaramie98 is offline
Vehicle: 1998 dodge ram
Trim Level: SLT laramie
Rep:12
blacklaramie98 is on a distinguished road
Default Grinding noise
I have a 1988 dodge ram and when I drive over doors bumps or potholes, it sounds as though something is grinding or rubbing together. I have looked underneath and can't find anything. I've replaced the sway bar bushings so I know it's not that. Any help is appreciated
Old 08-07-2013, 04:00 PM
DaSOB's Avatar
DaSOB DaSOB is offline
Vehicle: 1998 Dodge Ram Ext Cab
Trim Level: SLT Laramie
Color: Light Driftwood Satin Glow
Rep:51
DaSOB will become famous soon enough
Sounds like whatever is causing it is happening when you bottom out the suspension, or at least hit a good enough bump to cause it to nearly bottom out. My first suspicion would be that the wheel is rubbing on something. What shape are your stop bumpers in? If they're in bad shape, maybe the control arms are moving up far enough to let the tire rub.
Does it sound like a harsh grinding, or more like something rubbing?
Ah Luv Muh Truck!!
http://www.ramforumz.com/signaturepics/sigpic2117_1.gif
Old 08-08-2013, 12:51 AM
Rep:12
It's a harsh grinding, I had my tires run before but I lifted my truck 3in and that solved the problem. My bumpers in fairly good shape except the plastic moldings are pretty loose
