Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 08-07-2013, 07:05 PM
letsgo19 letsgo19 is offline
Vehicle: 1998 ram 2500
Trim Level: 2500
letsgo19 is on a distinguished road
Default trailer brake controller
My 1998 2500 ram came with a brake controller.I"ve never used one before.So in what situation are they most useful,and do I need to adjust it for my towing needs?Thanks.I trailer a 3000 lb boat.
Old 08-07-2013, 09:01 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2549
The brake controller is suppose to relay your brake applications to the trailer brakes, which in turn, applies the trailer brakes, so the trailer is not "pushing" the truck on stops. There are two kinds, the better examples are progressive which means, if adjusted properly, will apply the trailer brake in proportion to the pressure you apply in the truck. The not so good models, kind of guess how much and when to apply brake pressure. So, as a result you get a jerky un-reliable braking performance at the trailer. Makes backing operations a real headache. You say yours came with the truck so a good chance it is a OEM brake controller, but perhaps not. If it is OEM that would be good, but there are a couple very good aftermarket brake controllers. You will know if it is OEM, because the unit itself will be recessed into the dash and most likely the display will be on your dash display. To adjust, generally you set it for a mid point number, travel on a level flat and dry surface at approximately 20mph and then manually apply the trailer brakes from the controller. If the trailer brakes lock up, then you need to reduce the power number until the trailer brakes no longer lock-up. If they do not lock-up, increase the power until they lock-up, then back off the power slightly. Properly adjusted, you will get maximum braking to the trailer without locking them up.
Old 08-07-2013, 09:13 PM
PaulMys PaulMys is offline
Jan 20. Sad Day
Vehicle: no car
Rep:3248
PaulMys has disabled reputation
Could you go into a little more detail? LOL! JK, Bruce. Great info man!
Old 08-08-2013, 04:34 AM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Trailer brake controllers are for electric brakes. Your boat trailer most likely has surge brakes which don't require a controller, if it has any brakes at all.
Some newer higher end boat manufacturers are starting to put sealed electric brakes on their trailers.
Old 08-08-2013, 12:08 PM
Vehicle: A Truck
Rep:2549
Geez Paul, that was the Readers Digest version. But since you asked.... four score and seven years ago.
Good point, it has been so long since I was towing boats, I forgot about this important point and have not followed the boat trailer technology.
Old 08-08-2013, 02:29 PM
Trim Level: 2500
Thanks for the replys and great write upHow do I tell if my trailer brakes are surge or electric?I think my dealer told me the trailer brakes engage when I apply truck breaks.
Old 08-08-2013, 03:18 PM
Vehicle: A Truck
Rep:2549
If your trailer has surge brakes, there is no electrical connector to the trailer, other than a 4-pin for lights and signals. With surge brakes, the brakes are activated by a connection through the hitch, if I recall correctly. If your trailer has electrical brakes it will have what is called a 7-pin Bargeman plug which will mate with your truck electrical connection. The 7-pin plug has the wiring for the brake controller as well as lights.
Old 08-08-2013, 03:35 PM
Trim Level: 2500
Thanks,ya my trailer only has the 4 pin connector.
