Old 08-07-2013, 09:25 PM
ubok4mee ubok4mee is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: XLT
Color: Blue
ubok4mee is on a distinguished road
Default 2013 ram transmission
i have a 2013 ram 1500 with a rough country edition. 35 x 12.5 x 20's, 6 inch suspension lift, 4.7L, 6 speed trans.. The truck feels like it is shifting too fast. Can this be corrected?
Old 08-07-2013, 11:14 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
was the truck speedo reset for larger tires? that should change the shift pattern.
Old 08-08-2013, 08:23 PM
Trim Level: XLT
Color: Blue
Speedo and tire pressure sensor were re-calibrated and I even checked it again to be sure. I heard the computer can be flashed, is there any truth to that? The truck feels sluggish due to shifting and at times the shifting holds out and the truck runs great?
Old 08-08-2013, 08:30 PM
maw76's Avatar
maw76 maw76 is offline
Vehicle: 2013 RAM 1500 QC
Trim Level: Outdoorsman
Rep:49
maw76 is on a distinguished road
need to get a tuner and adjust the transmissions shift points to how you like them most tuners for the 4.7L have this option not sure about the 6 speed but most likely if it works off of pressure the resistance from the tires most likely what is causing her to shift early. That being said tranny might run hotter cause once adjusted might look into a cooler for it to be on the safe side.
Old 08-09-2013, 09:10 AM
Trim Level: XLT
Color: Blue
Thanks for the info, I'll look into the tuner.
