Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 08-08-2013, 09:34 PM
first truck 85 dodge first truck 85 dodge is offline
Vehicle: 1985 dodge ram d150
Trim Level: enough
Color: two tones of blue
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
first truck 85 dodge is on a distinguished road
Default 1985 dodge ram d150 if I lower her do I need to do anything to the suspension
I need help finding the cheapest way to lower my 1985 dodge ram 1500 prospector and I want to have to smoothest ride possible I've heard u feel every bumb if u lowere them is this true an how do I make it a smooth ride
Old 08-20-2013, 11:28 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
There are a number of ways to deal with ride quality. Cheap checks have to do with tire pressure. type and status of shocks, springs. Lower a truck would need to use some suspension modifications at least. From here is how much do you have or want to spend on lowering. What ever you do make sure it is safely done. One of the ways is to move the springs from top of axles to the bottom and if you are not hauling heavy loads go with a softer shock setup.
Old 11-27-2013, 02:28 PM
DodgeAddict's Avatar
DodgeAddict DodgeAddict is offline
Vehicle: 9 trucks form 77-97
Trim Level: SS/T Adventurer SE
Rep:42
DodgeAddict is on a distinguished road
I use 78-98? Dodge Van lower control arms in the front & depending on how I'm using the truck decides whether I flip the rear axle or move the hangers up on the frame
My wife says I'm addicted to Dodge I have the CCDD chromosome in my DNA It's genetic!
Old 12-07-2013, 11:00 PM
Rep:42
This is 5/3 using Van LCA's,225/60/15 in the front Axle flip & 255/70/15 in the rear
Old 02-25-2014, 01:32 PM
M109R M109R is offline
Vehicle: 2006 Ram 1500 Big Horn----
Color: Pearl White
Rep:28
M109R is on a distinguished road
DodgeAddict, how did you flip the rear axle? Did you have to weld new spring perches on the axle tube to put the axle over the leafs rather than under? Or is there a easier way?
2006 White QC Big Horn- Hemi
2000 Maroon Ext. cab- 360
Old 03-08-2014, 07:18 PM
Rep:42
I used Mopar Performance perches & drilled the locating hole forward of center to keep from having the shorten my driveshaft New u bolts from o riellys & shock plates from an early C body
You can buy it all at Speedway Motors
Old 03-24-2014, 01:48 PM
Color: Pearl White
Rep:28
Would you happen to have the part numbers of the parts you used? I searched speedwaymotors.com but didn't find the parts I was after? I just wanna make sure I get the correct parts the first go around lol.
