2010 Ram power door lock actuater replace - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-08-2013, 11:03 PM
ffrickbair ffrickbair is offline
Trim Level: Big Horn SLT
ffrickbair is on a distinguished road
Default 2010 Ram power door lock actuater replace
Help, my power door lock on the passenger side front door lock isn't working I purchased the actuater and went to install but unable to remove the old one fronm the bracket any ideas on the removal and the only access is a small hole help please
Old 08-10-2013, 08:05 AM
thebluegoat thebluegoat is offline
Vehicle: 2011 Ram 1500
Color: Deep Water Blue Pearlcoat
Rep:49
thebluegoat is on a distinguished road
Can you take some pictures of what you're working with?
Old 08-12-2013, 07:53 AM
joeAEKDB's Avatar
joeAEKDB joeAEKDB is offline
Trim Level: Demon
Color: Mango Tango Pearlcoat
Rep:520
I just did this with my drivers door. You have to remove that whole plastic carrier assembly. The module only can be removed from the backside. The only reason that the access hole is there is to get to the clips for the window, because it also has to be removed from the track. The other window clip is behind the speaker. just make sure that you either get someone to hold the window up or tape it up. If it falls will shatter.
