Old 08-08-2013, 11:36 PM
Draze Draze is offline
Vehicle: 2010 Dodge Ram 1500 4x4 Sport
Draze is on a distinguished road
Default Lift and Performance...
I have 2010 Dodge Ram 1500 4x4 Sport looking to put on a 2-2.5” leveling kit to make room for some new 35” tires. I will also be adding a cold-air intake and performance chip to help improve fuel economy (that Hemi can suck some gas, but sure is fun stompin’ on the throttle) At present time rear w/w height is approx. 39-40” / front is approx. 36.5” and I have 33” tires on 20x11” rims. I figure a 2-2.5” lift will leave a little bit of rake for when I’m towing my trailer or have a load in the bed. Here are my questions, recommendations on type/brand of lift (i.e. Bilstein or Daystar): suspension vs. body? Should I go all out and purchase new shocks or just add in the puck-style spacers? With a 2-2.5” lift will that be enough clearance for the new 35” tire I want to put on? Onto the cold-air intake and performance chip, I’m leaning toward the K&N cold-air intake as I already have a K&N oil and air filter and prefer to keep things consistent; however I am unsure with little direction on the performance chip? All suggestions and recommendation are greatly appreciated. Thank you.
~D.Maser
Old 08-08-2013, 11:45 PM
Welcome to the boards
As for leveling, it will all depend on how much you want to spend. Cheaper option is a spacer block an ideal option is Bilsteins as it levels and swaps,out yor shocks for something better.
Full blown suspension? Not needed.
Level spacer $100
Bilsteins $218
As for intake? There is a wide array of choices. And this will depend on preference as many fall with the same dollar amount.
Many here run vararam, S&B, Airaid, aFe and K&N
If you like the K&N, stick with it. CAIs are more noise than anything. True performance intake is the vararam
Any help or pricing, let me know and I'd be glad to assist.
Old 08-08-2013, 11:51 PM
Untamed's Avatar
Untamed Untamed is offline
Color: Grey
Untamed is on a distinguished road
My rough country 3.75" combo lift kit did the trick well. The Bilstein 5100 shocks seem to be a very good way to go for a 2.8" max front lift also. You will need 1/4" spacers minimum to fit the 35" tires if they are 12.5" wide.
For Programmers, Superchips or Diablo are the most common selection for our trucks.
- 3.75" RC Combo Lift - 20" Zinik Wheels - Mud Grapplers - EGR Rugged Flares - Magnaflow 14" -
- IAFF Local F-160 -
Old 08-08-2013, 11:53 PM
Bold part is correct
What he said too about the programmer.
Most reliable and chosen tuner for your year is the superchip flashpaq
If you'll be buying a new ram in a few years, I'd recommend the diablo as its moveable to another vehicle
Old 08-09-2013, 06:52 AM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
I suggest the bilstein 5100 too.great for a level, plus if you ever decide to get a lift it will level the lift too as they are adjustable
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
