Old 08-09-2013, 12:13 AM
Justin2253's Avatar
Justin2253 Justin2253 is offline
Vehicle: 2013 ram 1500
Justin2253 is on a distinguished road
Default 2013 ram info
Recently I have been looking for a new truck and I have been looking at the 2013 ram 2500 SLT with the 5.7 (hemi) and the 2013 ram Laramie, both 4wd. But the Laramie is catching my attention a lot, but one thing that I saw on the Laramie is that it has air ride so If I put a lift in the future what will happens to the air ride system. PLZ REPLY IF YOU HAVE ANY INFO
Old 08-09-2013, 07:56 AM
Bruce E's Avatar
Bruce E Bruce E is offline
Vehicle: 2013 Ram Longhorn Crew Cab
Trim Level: Longhorn
Rep:55
Bruce E will become famous soon enough
You can not lift a truck that has the air ride suspension. That is why I stayed away from that set-up. You can still get the Laramie with a conventional suspension that you can put a lift on.
Vararam Cai, ARE Cap, 35" Dick Cepek Mud Country, DC-2 Wheels, Diablo Trinity.
Old 08-09-2013, 11:44 AM
Justin2253's Avatar
Thanks for the reply, I did not know that but now I know. Thanks for the info because I would tried to put a lifted or leveling kit on it right away. But can you put bigger tires on it or you can only leave it stock.
Old 08-09-2013, 11:48 AM
Bruce E's Avatar
Rep:55
I would use caution on this, as the air suspention lowers on its own as I understand it when in park and also when operating at highway speed. I would think this could cause clearance issues.
Old 08-09-2013, 12:04 PM
Champ1264 Champ1264 is offline
Rep:17
Champ1264 is on a distinguished road
I researched this as well before I bought mine. I stayed away from the air suspension for exactly those same reasons. Can't even level them out. I also drove both before I started searching for the truck I wanted. I honestly couldn't tell the difference between the two, so spending an extra $1,500 weighed in heavily here. I'm perfectly happy with the standard suspension; I pull a big bass boat but that's about it, the truck is way more than adequate for that.
Old 10-23-2013, 12:59 AM
Justin2253's Avatar
Y'all both have 2013 have done anything to your truck like lift or level with tires and if you did, did it mess up y'all warranty.
