Old 08-09-2013, 05:52 AM
burtonxrider21's Avatar
burtonxrider21 burtonxrider21 is offline
Vehicle: 2012 dodge ram 1500 sport
Rep:92
burtonxrider21 will become famous soon enough
Default Is anyone running the JBL GTO-501EZ amp?
Hey everyone, I was wondering if anybody is running the JBL GTO-501EZ amp to power a sub? I have the Alpine system and want to install a new sub/amp and keep my stock head unit. From what I read you can use this amp without a LOC and take your signal from the stock subwoofer wiring. It sounds too good to be true! While we are on the topic of LOCs... Where is the best place to get your signal/feed? some people say the front door speakers and others say the rears... Are you able to take it from the stock sub wiring??? Any info woul be greatly appreciated!
Thanks in advance!
Old 08-09-2013, 05:32 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
I'm running their 4-channel. There's none easier to install. For the Sub amp, grap your high-level inputs right at the sub in the rear. OE is a DVC sub -- with 4 leads. Run those to the JBL-provided bare wire-->RCA connectors. Make sure to have the switch correct on the bottom of the amp. Run your ground to bare metal. Run your power to battery. You are done. There's no need for a separate remote turn-on. I had 0 noise, and 0 turn on/off thump.
In my case, I did have to later add another device, but that's because I needed a full-range signal. If only adding a sub, the JLB EZ will be perfect.
PS -- I have the OE wire codes if you need them.
Old 08-11-2013, 12:22 AM
Rep:92
Thanks for the reply! That sounds like a good way to go! If you could send me the wire codes that would be great!
Old 08-12-2013, 01:10 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Is this what you need? Looks like they use the wire from the sub to connect to the amp for the left & right channels.
I am thinking of doing the same thing and may try to use the OEM sub and an external amp. If that doesn't work I will then go with a new sub and amp. I don't need booming base, just want more base.
https://loopfamily.com/Hosting/Ram/S...Wiring_RCA.png
Hope this helps.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
