Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 09-18-2013, 03:59 PM
jeb6294 jeb6294 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: SLT - Big Horn
Color: Grey
Rep:18
jeb6294 is on a distinguished road
Default Tired of This @#$%^ Squeal!!!
'09 Hemi and I've had a bad squeal since I got it. Dealer has taken it in twice. First time they just replaced the belt. Second time they replaced the tensioner. Both times the squeal went away for a day or two then came back. After this last time I stopped at Harbor Freight and got a stethoscope. I stuck it against the idler pulley and, plain as day, it sounded like that was definitely where it was coming from. Since it was only $15 I ran up to O’Reilly’s and picked up a new Gates pulley. Not only did the noise not go away, I think it is actually worse. I haven’t had a chance to check and see if that’s where the sound is still coming from. What is going on?
Video is from before the "fix" but sound is the same:
Old 09-18-2013, 05:12 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I'd replace the belt with a Good Year Gatorback...always solved the problem of belt squeal for me
Old 09-18-2013, 08:16 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Your dealer should be taking care of that for you, especially if that is your original complaint described on the repair order from the get go. They have not fixed the squeal even after replacing parts. It could be anything from the bearing in your alternator to your bearing in your AC compressor. You sound like you're close to finding the culprit. Just process of elimination. Great luck man and let us know what your end result is.
Old 09-19-2013, 11:00 AM
Color: Grey
Rep:18
That's why I took it back to them in the first place. It was there during the test drive and the salesman told me it would be fixed. If it was just the idler pulley I could have done that pretty easily myself but if it ends up being something a lot more costly then I don't want to let them off the hook.
Old 09-19-2013, 05:21 PM
hodge's Avatar
hodge hodge is offline
Vehicle: 2011 Dodge Ram Sport
Rep:26
hodge is on a distinguished road
My truck has done the same thing since the day I bought it (used).. Dealer said it was the belt and replaced it, but the noise came back shortly after. Mine is more apparent in the damp though. I'm interested to see your end results. Good luck
RCX 2.5" level - 1.5" Zone Body Lift - 295/65/20 Trail Grapplers - 20x10 Moto Metal 970 - Debadged - 18" Magnaflow and Y-Pipe - S&B CAI - DiabloSport Intune DCX
Old 10-05-2013, 08:28 AM
3nitros 3nitros is offline
Vehicle: 2010 dodge ram slt
3nitros is on a distinguished road
see if the ballancer has moved at all we had a chevy at my shop with the same problem and it turn out the ballancer had moved
Old 10-25-2013, 09:09 AM
Color: Grey
Rep:18
Just a follow-up. They took it back for the third time the other day. I've had it back about a week now and so far the noise has not come back. On the paperwork this time it shows they put on another new belt but this time it says they also aligned the PS pulley.
Old 10-25-2013, 10:13 AM
anothernewb's Avatar
anothernewb anothernewb is offline
Vehicle: 2013 Laramie Crew Cab
Color: Dark Cherry
Rep:162
anothernewb has a spectacular aura aboutanothernewb has a spectacular aura about
my GMC squealed like a banshee every time it shifted at higher RPM's. fought it over and over, finally narrowed it down to an alignment issue between the different rotating elements. Belt wasn't really contacting with all it's surface area, causing uneven tension. Took some grinding and some creative shim work using old pop cans, but it did fix it. we also roughed up the pulley surfaces a bit to add more grab
mind you - this was one of those - here hold my beer adventures. I don't have the truck anymore, but it was that way for a good 20,000 miles, who knows what, if any, of longevity of the components was affected
there's a belt dressing spray out there - have you ever tried that stuff?
Livin life one truck payment at a time.
Old 10-25-2013, 12:50 PM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
Mine squeals in the morning when it's cold, I have the belt and new idler bearing but haven't got around to changing them in a year...of course, now that the cold is here, I just park further up on the street so I don't have to hear it
