Old 08-10-2013, 01:32 AM
Twilly12 Twilly12 is offline
Vehicle: 2001 ram 4x4
Trim Level: Work
Twilly12 is on a distinguished road
Question New ram 4x4 owner transfer case whine issue
Just bought a 2001 ram 1500 5.9 4x4 today so I'm driving it around being proud of my truck and I noticed a little bit of a whine coming from the transfer case anyone experience this? And this is while it was in 2wd also when I put it in 4wd there was some grinding. Any information will help thanks a lot.
Old 08-10-2013, 08:51 PM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
bring it back to dealer and complain, NOW
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 08-10-2013, 08:56 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Twiily12; this sounds like a job for TransEngineer. I know the man is filled with tremendous knowledge and experience on this subject.
Old 08-11-2013, 01:56 AM
Trim Level: Work
Well it is a 2001 that I bought from a private seller and is TransEngineer on here?
Old 08-11-2013, 11:51 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
He is on here.
First off, I'd check to make sure there's enough/good fluid in the transfer case.
How did you shift into 4wd?
Old 08-12-2013, 02:58 PM
Trim Level: Work
Fluid looked brand new and full and shifted into 4wd in park and then again in neutral
Old 08-12-2013, 06:14 PM
Rep:326
4Hi or 4Lo?
Just curious since you're a new owner.
Old 08-12-2013, 07:59 PM
Trim Level: Work
The grind is going into and out of 4lo the whine is 40mph plus in 2wd
Old 08-12-2013, 08:36 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
slight grinding into and out of 4 low is normal. If I remember correctly from my 2000 ram 1500 either the owner's manual or behind the visor are instrustions for 4x4 use. I typically always try to shift into 4L with gear shift in neutral while coasting 1-2mph. For the whine in 2H any way to see if he rebuilt or upgraded something in it? Are you sure the whine is coming from the transfer case?
Old 08-12-2013, 09:28 PM
Trim Level: Work
Not completely positive on the whine but it is loud in the cab and starts to whine around 40 mph and never gets any louder at increased speeds and if I let off the gas the noise goes away
