Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
MOPAR DECALS
Old 08-12-2013, 09:59 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Shifting 4Lo can grind from a stop. Like Simple Guy, I try and shift into 4Lo while rolling under 3 mph.
I'm wondering if the whine isn't from something else.
Old 08-14-2013, 03:15 PM
Twilly12 Twilly12 is offline
Vehicle: 2001 ram 4x4
Trim Level: Work
Twilly12 is on a distinguished road
It is possible it just sounds very similar to the whine a t case make when you go to fast I'm 4lo an old mechanic family friend told me those years have a problem with rear axel bearing so I'm gonna check that out
Old 08-14-2013, 07:21 PM
Rep:326
It could be the rear axle... Mine was rebuilt before I got it. I think at 95k miles.
Old 08-14-2013, 07:42 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
if it is in the transfer case it kind of sounds like a noisy bearing. i had an isuzu trooper that had a noisy bearing on the output shaft, it lasted for 5 years whining away. it always sounded like a cheap import manual trans in reverse. but look for play in the driveshaft yoke to see if a bearing is going on it. is there any vibration?
Old 08-15-2013, 01:28 AM
Trim Level: Work
That is very similar to what it sounds like and when I checked the u joints everything seemed tight and there is no vibration. Might just have to fork out the cash to have it diagnosed
Old 08-16-2013, 11:50 AM
Rep:68
keep us informed if you find it.
Old 08-16-2013, 11:59 AM
Rep:326
If you are driving, do you hear a whine, then it goes away when you lift off the gas?
Old 08-16-2013, 09:09 PM
Trim Level: Work
Yes the whine starts at about 40 mph and is constant at any speed above that and when I lift of the gas it goes completely away and will do mb power wagon
Old 08-16-2013, 09:24 PM
Rep:326
I'm betting its your ring and pinion or bearings. My POS truck is doing the exact same thing, but I couldn't really hear it over my exhaust until a shop pointed it out this morning.
Sad thing is, my axle was rebuilt by the previous owner a year and 3 months ago, and the shop that did it is out of business. Only 11k miles on it.
Edit: I'm going to check the fluid level in the differential tomorrow. Hopefully, that could be it, but knowing my luck, it probably isn't.
Old 08-18-2013, 01:32 PM
Trim Level: Work
Ahhh man sorry to hear that. Let me know what you find out.
