Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 08-10-2013, 08:48 AM
Fnordian Fnordian is offline
Vehicle: 1999 Dodge Ram 1500 Quad
Trim Level: Laramie SLT
Color: Black & silver
Fnordian is on a distinguished road
Default leaf springs
Hi all,
I'm brand new to this forum, so if I slip up or ask a stupid question, please don't flame too hard
I was told by a shop that I need to replace my leaf springs.
Is getting some from a junkyard a smart option for a very strapped college student, or should I bite the bullet and get them new?
Anyone know of where I could locate some on the cheap?
'99 Ram 1500 SLT Laramie 5.9 with 138k miles on it.
Thanks in advance!
Old 08-10-2013, 03:02 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Personally, I'd just get a set from a junk yard. I'd also replace the bushings while you have them out.
Old 08-10-2013, 05:49 PM
Mcj.kd0hzi Mcj.kd0hzi is offline
Vehicle: 1996 Dodge Ram 1500 ext cab
Trim Level: SLT Larimie
Mcj.kd0hzi is on a distinguished road
Default replacing leaf springs
Hello. so I am also trying to replace my leaf springs on a '96 Ram 1500 4x4. does anyone have a good trick to actually being able to get to nuts and bolts off so that you can replace them?
I have a replacment set that came from a 2nd gen Ram 3500. so yes I know these will probably make the rearend ride rougher.
but a thought I had is...these replacment ones are still bolted to the brackets that are normally riveted to the frame....would it work to just get the rivets cut off on my truck...and then put in hardend steel bolts to replace the rivets...so that that way the bolts dont have to come off that actually hold the leafs to the brakets?
Sorry if this is a dumb question. . but I thought this might be an easier way to replace them.
Old 08-10-2013, 06:15 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
Interesting...you do know that 1500 springs are 2.5 inches wide and 3500 springs are 3.0 inches wide right?
This isn't an issue if you intend on replacing both front AND rear spring hangers with the 3500 ones...it will require you to remove the gas tank and most likely relocate the spring perches on your rear differential as well. This will require a proficient welder.
If you'd rather not do all that simply cut the bolts off the 1500 springs with a swazall and replace with new ones.
Old 08-10-2013, 06:20 PM
Trim Level: Fleet
Rep:47
Originally Posted by Fnordian View Post
Hi all,
Thanks in advance!
What is wrong with your springs? Are they broken or just sagging?
If they're sagging...
I think BDS still makes a 3 inch AAL for your truck. I'd buy that and install it. You won't have to remove your springs but you will have to disassemble your spring pack so you'll need to drop your differential.
Old 08-11-2013, 12:26 PM
Thank you!
Let's pretend for a moment that I'm not super mechanically savvy and I have no idea what half of that means... could you dumb it down a bit for someone who doesn't know what AAL, spring pack or "dropping my differential" means?
Thank you for your patience
Old 08-11-2013, 11:21 PM
Rep:326
AAL is an add a leaf. It will add a little lift to your truck and can strengthen your springs.
Spring pack is all the leaf springs for one side.
Dropping the differential is just removing the u bolts on the springs and lowering your rear axle to gain clearance so you can add or remove springs from the pack.
Hope this helps.
Old 08-12-2013, 12:09 AM
Hope this helps.
Indeed it does, thank you for taking the time to explain.
What advantages or disadvantages would adding a little lift do for the truck if I'm not doing anything off the road?
Old 08-12-2013, 10:03 PM
Rep:326
The advantages in your case would be that your springs would be closer to the arch they had when they were new. The truck won't squat as much with a load.
There are no real disadvantages, other than maybe a little stiffer ride.
Old 08-13-2013, 11:05 AM
Trim Level: Fleet
Rep:47
Hope this helps.
I'm not sure I want to "dumb this down" too much more. You'll need to remove your differential entirely from the bolts holding it to the spring pack. You'll need to replace those bolts because they are stretch to torque.
I would recommend clamping the leaves with c clamps then cutting the small bolt in the center of the spring pack. This wiil relieve the springs but the clamps should keep them from flying about.
Remove the clamps and insert the AAL where it belongs in the pack and then reverse the above processes...
BTW if you don't have the jacks and stands or tools to properly do this...don't!
