Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 09-04-2013, 09:30 PM
G8tkeeper's Avatar
G8tkeeper G8tkeeper is offline
Trim Level: 1500 Big Horn
Color: Blue
G8tkeeper is on a distinguished road
I just used mine for the first time the button seemed to work but the window seem to stick and jerk a couple of times
2010 Ram Bighorn stainless bull bar, nerf bar, window tint, flow master 40 series. Newly added remote start and 13" JL sub.
Old 09-22-2013, 09:36 PM
balki420 balki420 is offline
Vehicle: 2010 Ram
Color: Inferno Red
Rep:49
balki420 is on a distinguished road
Hey all. I had this EXACT same problem (luckily while it was still under warranty). Same symptoms as you all describe. Finicky, especially when the cab of the truck is hot from being in the sun. Rarely acted up when it was in the hands of the dealer. They replaced the motor, but that didn't change anything. When they replaced the switch in the overhead console, it's worked perfect ever since. I watched them change the motor, and that was a hell of a job. Didn't see them do the overhead switch, but it was done quick, so I'd definitely start with that end of the circuit. Faster, cheaper and proven in my case to be the fix.
Good luck!
-Balki
Old 09-22-2013, 09:59 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2471
I did have this happen to me only once a couple of years back, window would not close. Never had anything changed and to this day the problem has never repeated.
sales@revelperformance.com
Old 09-25-2013, 02:47 AM
brondondolon's Avatar
brondondolon brondondolon is offline
Vehicle: 2009 Dodge Ram 5.7L hemi
Trim Level: 1500
Rep:177
brondondolon has a spectacular aura aboutbrondondolon has a spectacular aura about
Join the club... ive had that sliding rear window motor replaced 2 times and it still doesnt work. worst part is my bumper to bumper warranty is expired. now i just act as if i dont have that option. its much easier for me to cope this way lol
S&B CAI, Y-pipe muffler delete, Diablo intune, Hemifever, custom tune, 180 thermostat, BT oil catch can, smoked, tail light and 3rd breaklight, 5000k retrosolutions 55w HID headlights and fog lights, LED in all exterior lamps, red calipers. Future mods: 87mm TB, 3000 stall torque converter
Old 02-16-2014, 07:56 PM
S77R's Avatar
S77R S77R is offline
Vehicle: 2010 Dodge Ram 4X4
Trim Level: Crew Cab SLT BigHorn
Color: Inferno Red
S77R is on a distinguished road
I agree with Balki, I have since noticed mine on does this in the summer when it has been out sitting in the sun.
2010 RAM CrewCab BigHorn 5.7L Hemi - 3.92/LS
18" Boesch Muffler kit - Moroso Catch Can
Old 06-02-2014, 09:21 PM
judiquer judiquer is offline
Color: grey
judiquer is on a distinguished road
I have found all the same problems with mine, On hot days, it opens fine and then either, doesn't close or it takes a few tries to do it. I also had my button push in. but I was able to reseat it using twine. I came on this forum to see if anybody has any problems. I am an electrican and the next really hot day and it starts happening I am going to start checking the motor and go back from there. I will keep you up to date.
Old 06-02-2014, 09:23 PM
Color: grey
thanks I'll try this first
Old 09-22-2014, 04:28 PM
mopar1265 mopar1265 is offline
Vehicle: 2014 Ram 1500 crew cab 6.4'
Color: Maximum Steel
mopar1265 is on a distinguished road
I also have this happen on warm / hot days. The console gets real hot. Window opens fine in the morning and when i go to leave for lunch i cant close it. I found that while your waiting on the dealer as i am, if you run the A/C for a little bit to cool the interior you will be able to close the window as normal.
Old 09-22-2014, 08:52 PM
S77R's Avatar
Color: Inferno Red
I finally ordered a new console switch and installed it a few months ago and the window has been working perfect ever since even in hot weather. Guess these are cheap switches that after a few summers finally go bad. It was like $20, so atleast it is a cheap fix.
Just be careful when prying out the switch as the plastic bezel can break. Found out the hard way and you cannot just buy the switch bezel from the dealer, you have to by then entire console so i had to rig up the bezel with some glue!
